Thread: HELP have fault codes but still cannot find cause.
    Lancashire
    Default HELP have fault codes but still cannot find cause.
    OK to cut the story had overcooling problems with my 1.8 ls 53reg changed the thermostat housing and sensor which knocked ecu warning on and disabled temp gauge, had the car hooked up today by a very kind m8 and the following codes have been found. strangley my m8 was unable to access the coolant system diagnostic mode which he should have been able to.
    My question is is there a master relay for this system causing this fault or a control unit it that is faulty. Or is the cooling system at fault. I think p0571 + p1565 are unrelated although if anyone has any ideas on these i would be gratefull.
    U2103 - Fewer Controllers On Bus Than Programmed
    P1565 - Cruise Servo Position Sensor
    p0571- cruise control brake circuit
    P0115 - Engine Coolant Temperature (ECT) Sensor Circuit
    • P1481 - Cooling Fan Speed Sensor Circuit
    • P1482 - Cooling Fan Speed Output Circuit
    • P1483 - Engine Cooling System Performance
    milton keynes
    Did the P1481 , P1482 and P1483 codes come up , if so locate the engine ecu , I have the DTI so will be in a different place to mine. Once located unplug it and spray WD40 in the connector and the on the ecu contacts. worked for me when I was get P1480 errors
    Lancashire
    Thanks kman will try it now fingers crossed will be this but am not hopefull.
    Lancashire
    Nope, unpluged ecu and stat sensor sprayed with contact cleaner and replaced but no joy.
    milton keynes
    Quote Originally Posted by REDBULL1717 View Post
    Which ecu did you spray ? needs to be the engine ECU not the ABS one, also I tried an IPA based spray and it was no good , WD40 and it sorted it . Think the contact cleaner sprays can actually leave a residue that gives bad contacts , well in my experience.
    I used contact cleaner before when i used to DJ on my mixer sliders , I had nothing but trouble , so I just use WD40 as it has solvent in it.
    Lancashire
    no tried wd40 and lights still on thanks tho. anybody any other suggestions?????????????
    Does your cruise control work? If not have a look at replacing the brake pedal switch.
    WGAF#5
    wont the light stay on unless cleared by tech 2 or 20-30 clean starts .....
    maybe quicker if you disconnect the battery for half an hour to see if its cleared
    but make sure you have the radio code and know how to reilintialise your auto close/open on the windows
    Lancashire
    cruise control did work very rarley needed a couple of presses but now not a sniff.
    Also had the system reset when had the codes read was bosch ktx i think same as tech 2 (£5500 worth). my concern is why the bosch system could not tap into cooling circuit at all to perform any diag tests. Is there a control unit or relay that could be the culpritt, i kno this is a bit of a techy one but if i take to vx they are gonna have same issues of not being able to diag the cooling circuit but charge me for the time it takes to figure it out. if i go in with an idea of what it could be might save a few quid labour any ideas gratefully recieved. thanks for responses so far guys.
    Lancashire
    just to add the temp gauge hardly functioning and i dont seem to be able to get the rad fan to cut in. just worried might case head gasket issues or car running in limp mode all the time.
  1. help needed to fault find (or read codes) 2.0DTi
    By FLOB in forum South East (ARO jaqubek)
    Last Post: 4th April 2012, 18:15
  2. How to find error codes?
    By luckyracer in forum Engine & Drivetrain
    Last Post: 13th March 2012, 20:56
  3. what are these fault codes?
    By vectragsi3.2 in forum Engine & Drivetrain
    Last Post: 8th January 2011, 16:05
  4. Help with 2 fault codes Please
    By Luke1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2010, 17:42
  5. Fault Codes
    By Hyperhart in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2010, 18:54
p1481 cooling fan speed sensor circuit vectra c
vectra c fault p0571
