Results 1 to 10 of 22
Thread: cdti 150 gear changes...
    Regular Member Fash's Avatar
    Doncaster
    Default cdti 150 gear changes...
    Whats the best rev range to change gear on the cdti 150? Is 3000 revs ok for 1st and second ? Not had the car long and don't want to do owt silly
    Ta,
    Steve
    Merseyside
    Its horses for courses mate.
    For normal driving, personally I change 1 - 2 @ 2500rpm and 2 - 3 at around the same engine speed.
    For motorway acceleration, eg joining, I will run it up to around 4000rpm in 3rd to get maximum acceleration out of it.
    As long as you dont over rev it, the motor will be fine, just a bit more thirsty at higher revs.
    Doncaster
    Thanks mate-Jody did say not to go too mad in 1/2 (as I did hammer it on the test drive, Lol), but wanted to check what was probably the best sort of range..cheers
    Merseyside
    I find that the max power is at 4000rpm on my 150, so I dont tend to run it past that point as it doesnt give any more power but uses more fuel.
    Power comes in at about 1500rpm via the turbo so its pretty much up to you what revs you use.....
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Blooming EK, i never tend to go above 2.5K, even at Mway speeds in 6th
    Merseyside
    When cruising, its 6th gear and just a shade over 2k revs. Only use the power to accelerate upto 70 mph then its cruising all the way. Dont make a habbit of raggin the balls out of the engine all the time.
    Regular Member boba's Avatar
    The Kingdom of Fife!
    Generally use around 3000 rpm for a nice brisk drive. When cruising I use a gear to give between 1500 and 2000 rpm wherever possible. First gear on the Vectra is stupidly low so I frequently take it up to 4000 otherwise you're on and off the pedals in a silly dance.
    Sep 2009
    Glasgow
    I find 1st gear hard to get any real power unless I rev to 3000-4000 and then it takes off like a rocket but have to change into 2 nd quickly to stay on the turbo as 1st runs out really quick.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    nice and steady in 1st and 2nd otherwise you will have to stop to go and pick up the gearbox
    then if you want to give some beans in 3 rd onwards
    it takes ages to get used to driving turbo diesels
    Cambridgeshire
    Quote Originally Posted by signum_1.9 View Post
    But also remember to take it through the revs every now and again otherwise it will clog up with soot and you get egr problems. There is also a theory behind the swirl valve problem that the car needs to be spanked every now and again to reduce the change of it failing.
    In other words, if you don't use it you'll lose it
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. gear box oil cdti 150
    By dave r in forum Engine & Drivetrain
    Last Post: 18th May 2011, 00:43
  3. torque 1st & 2nd gear 150 cdti
    By mparks8590 in forum Engine & Drivetrain
    Last Post: 31st March 2011, 20:13
  4. CDTI RPM at 70Mph in 6th gear
    By Mr_Me in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2006, 19:47
  5. CDTi 150 Gear Ratios
    By CBR600FV in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2006, 21:35
