Thread: recycle button
    Sep 2009
    bedford
    Default recycle button
    Hi All
    No light in recycle button any ideas
    Thank You
    WGAF#5
    do you mean the air recirculation button?
    it will only work dependant on the correct settings of the air vents....
    worse case scenario would be a blown SMD (surface mounted diode) ..
    regards
    Dez
    Sep 2009
    bedford
    Default Recirculation Button
    Thank You Dez
    I did'nt know it is dependant on the settings (that will teach me to read the book) thank you for the prompt reply
    Regards
    Graham
    Regular Member fandango's Avatar
    Nottingham-ish
    It won't recirc if the vents are pointing at the screen.
    If you have the vents pointing (even partly) at feet or face, then it works. Switch the dial to screen only and it will turn off automatically.
    WGAF#5
    Quote Originally Posted by BRUNO 15 View Post
    Thank You Dez
    Regards
    Graham
    Graham - no worries
    hopefully its just the settings rather than a SMD
  1. Boot Button vs Lock Button
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2013, 21:30
  2. sport button, traction control button
    By Denbro in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2012, 23:44
  3. Another Alternator destined for the recycle bin
    By RobW in forum Engine & Drivetrain
    Last Post: 12th April 2010, 21:05
  4. What does this button do???????????
    By craig1989 in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2010, 10:12
vectra c recycle air
