Results 1 to 3 of 3
Thread: Help please!!
    Oct 2009
    BASINGSTOKE
    Default Help please!!
    I have a 2.2 vectra SRI (03 plate) with 90k on the clock and it still runs perfectly as its well looked after…
    Until Tuesday last week it was a cold morning and got in my car to go to work started it up and the car started but was shaking like mad. When I put my foot on the accelerator the car cut out, this happened about 4 times before I gave one final go and the left it shaking and then it seemed like the revs kicked in and job done off I went to work.
    Driving the car to work it seemed the car was more like a 1.1 litre than a 2.2. 1st gear is fine on pull away and 2nd, 3rd 4th and 5th are a nightmare with no power at all. At one point I had foot to the floor in 2nd and it was doing about 30mph.
    I took it into a mechanic who has had it on the computer which shows no faults, he thought it may have been needing a new airflow meter which he changed with no luck. He has not idea what it is so I have to get it into vauxhall who charge £50.00 to even look at it… upon speaking with one of the service guys he said it would be the fuel pump as they have had similar problems. So while the mechanic I am using has it I asked him to check, all is clear fuel filter is 100% fine.
    Does anybody have any ideas what it is before Vauxhall slap a huge charge my way!!
    Thanks adam
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    hi and welcome to Vec-c............strange there was no fault found ....
    might be worth getting the mechanic to clean the EGR valve as they seem to cause a few faults on those deisel cars
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Hi was there any EML on (engine management light) on dash ? bit strange but if its ok upto 2nd gear it might be worth checking for splits or holes in the boost pipes
    Irmscher Insignia CDTI 130
