Thread: Rear break caliper + bleeding screw
    Oct 2009
    Eltham
    Eek Rear break caliper + bleeding screw
    Hi, i just changed rear brake pads for my vectra 2.2 Dti and was trying to do bleeding, just unfortunately twisted bleeding screw bit harder and the inner thread on caliper gonne. Does anyone has an idea ? thanx
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    if the thread on the caliper has gone its knacked i think. Motor factors should stock an exchange recon unit quite cheap
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Either that or ebay. You could always try to re-tap to a larger thread until you get a new one
    Or helicoil it.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Tapping or helicoiling any material always produces swarf even if you use a spiral grooved tap. Thus it would be easy to get swarf into the braking system which is not a good idea.
    Obviously you remove the caliper and strip it down before commencing tapping/helicoiling, then give it a good clean before re-assembling.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Exactly, flush it through with brake fluid and it should be ok until you get a new caliper
  1. Rounded off bleed screw - rear caliper
    By 19CDTi in forum Suspension, Wheels & Brakes
    Last Post: 15th June 2012, 10:34
  2. Rear break help
    Last Post: 30th May 2012, 21:18
  3. rear break problem Vectra Sri
    By universalwoman in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2009, 18:35
