Thread: engine temp.
    Regular Member Graeme01's Avatar
    Aug 2009
    wirral
    Default engine temp.
    what temp. does your 1.9 cdti 150 get to as mine is just touching 75'c which is quite cold i think
    Regular Member scottyd's Avatar
    paisley
    mine sits about 90 think your thermostat must be knackered
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Down to your local motor factors clutching the wallet, empty said wallet and come back to fit nice new themostate in its housing. It is located on the left hand end of the cylinder head, dont forget the new gasket, maybe in the box.
    Aug 2009
    wirral
    how much is it for a new one?
    Aug 2009
    wirral
    is there a difference between the 150 and 120 ones as the local motor factors only stock 120
    Jul 2006
    TENTERDEN KENT
    I have no idea on both as I have a 1.8 and buy just the thermostate not the casting as well, these cost £4 as I remember complete with gasket. I may be wrong, and if so someone will soon jump in, but I think the difference between 120 and150 is the extra camshaft with them both running at the same temerature, about 92c.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Mines been like this since day 1, and it runs great - temp goes up in traffic, but cruising (or with the heater on) the needle drops right down - doesn't worry me at all
    Lancashire
    a word of warning i had suspected overcooling and changed the stat/housing/and temp sensor on a 1.8ls which has lead to cooling system control unit failure, am still trying to find the problem but its only after new stat. maybe wise to check the return from rad on start up see if high pressure and warms with the rest of coolant hoses if not its prob not stat and maybe sensor or electrical fault???
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as redbull says bud, is your heater working ok ,your temp may be ok it may be sensor faulty
  1. what should teh engine temp be in 1.9 150
    By kirky2k4 in forum Engine & Drivetrain
    Last Post: 26th January 2011, 22:16
  2. Engine Temp.....
    By skip85 in forum Engine & Drivetrain
    Last Post: 30th November 2010, 01:51
  3. Engine Temp
    By bigmac in forum Engine & Drivetrain
    Last Post: 17th May 2010, 20:36
  4. Engine temp vvt
    By shadyone in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2010, 19:11
  5. engine temp
    By iasha in forum Engine & Drivetrain
    Last Post: 27th January 2010, 00:39
