Hi Guys,
after reversing into a pole on fridaywill need to replace the back passenger side light cluster.
Is there much involved in changing this ? had a look in the how 2 section but cant see anything in there
thanks in advance![]()
Hi Guys,
a couple (maybe three there are on the signum..) of twist bolts on the rear of the lamp unit (handbook shows you using the wheel brace to removenormally can be undone my hand)- unclip wiring harness - remove - remove rear cover and replace the bulbs into the new unit and then remount
five minute job![]()
cheers for that, fingers crossed wont need the wheel brace !! LOL
wow,was the girl still dancing around the pole ?
Cheers for that, the hand of god picked up two gazebos and hurled them across a field and straight through my rear light cluster. Managed to get a brand new one on Ebay for £29 delivered. Glad it's easy to fit.
dead easy m8 i changed mine the other month, i do have the advantage of fitting these all day on toyota avensis and auris as i work there and there all the same really, just 3 nuts and it pops out
