Thread: Loose gearknob
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Default Loose gearknob
    Any idea how to re-secure it ? There's a few mm of end float developed with an annoying pop noise everytime I change gear. It's in the actual knob, as if I hold the shaft securely, I can move the knob up and down
    Having reduced the young girl at the local dealers to tears querying whether I could claim warrenty for my knob, and explaining the above, she declined inspecting it.....
    I know there's a thread on how to remove one which involves destroying it, but I just want to re-secure mine.
    scotland
    Get it replaced under warranty. It will come off when driving, mine did.
    Can cause issues when you try and select first and end up in reverse, thank **** my reverse parking sensors beep when i hit reverse. Was a bit scary. hth
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Angry
    They claim this is not covered under warrenty despite the car only being 2 1/2 years old
    scotland
    I had a month left of my warranty when they did mine
    Regular Member mcwharam's Avatar
    Oct 2007
    Leeds
    Mine has started doing exactly the same. Annoying
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Default Same here
    Join the knob lifters club guys. I had the same problem, but as it was under two years old, they fixed it under warranty. In fact they replaced the whole stick/linkage and cover, albeit not with the same quality, but it works and touch wood is staying put. These things shouldn't happen nowadays!!
    kc
    Grantham
    Default Knob lifters
    Yeah, I'm a member - mine had that play until one day when changing from 1st to 2nd thing came off completely! The knob appears to be an interference fit and held in place by self gripping teeth on inside. It needs to be carefully aligned and smacked smartly downwards with flat of hand. After several 'pull-offs' it seems to be firmly held now.
    Just don't panic if comes off in hand as there is a spring inside which is used for the reverse selector.
    Thundersley
    Default Another one with a flying knob
    Exact same probs. It's been bouncing everywhere although I've got use to changing gear without it. I'll try the flat hand slap as suggested. Otherwise I'll try the warranty route. I would say it's actually a safety concern and clearly a sloppy design fault. Surprised Vauxhall have'nt done anything e.g. recall.
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    ............ah well. It finally came off in my hand, changing down coming up to a junction !
    At least I can get some glue on it now
  1. New Gearknob
    By Carl83 in forum Styling
    Last Post: 24th March 2012, 17:53
  2. What do I loose?
    By DaveD in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2009, 18:01
  3. Different gearknob..
    By ROY2593 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2008, 16:31
  4. At a loose end???
    By marichrd in forum General Chat
    Last Post: 27th June 2006, 21:51
vauxhall vectra gear knob falls off
vectra gear knob loose
vauxhall vectra gear knob problems
vauxhall vectra gear knob repair
vauxhall estate gear knob problemloose gear knob vectravectra c gear stick looserepairing gear knob on Vauxhall Vectra design how to lose opel vectra gear stickgear nobs for a vauxhallvectravectra design gear stickloose gear knob Vauxhall vectra 2006vauxhall vectra gear knobvauxhall gear knob looseopel vectra gear knob loosehow to fix opel cub gear knobloose gear knob corsa cvectra gear knob repair 07corsa gear knob loosehttps:www.vectra-c.comforumshowthread.php93837-Loose-gearknobvectra c inside gear knobgear knob for vauxhall vectravauxhall vectra loose gear knobgear atick know loose vectravectra c gear knob clicks site:www.vectra-c.com
