Thread: Cdr 2005 - safe
    May 2008
    Newry
    Default Cdr 2005 - safe
    Hi folks,
    Just spent the weekend replacing the starter in my 2003 2.0 DTI and now can't seem to get the CD player to ask for the code. I have followed the steps in the manual and have my code to hand but it wont move from safe to code to allow me to enter it.
    Any ideas?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    i should work hold AS turn off, then turn on keep pressing AS until it Beeps.. (its the radio to turn on/off)
    May 2008
    Newry
    Cheers Ken - I'll give it another whirl.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    As ken said turn ignition off then back on (dont start car) Then Press and hold the [ AS ] key and switch on Radio.
    'SAFE' will display followed by '10 - - - - '
    Press preset [ 1 ] repeatedly for the first digit
    Press preset [ 2 ] repeatedly for the second digit
    Press preset [ 3 ] repeatedly for the third digit
    Press preset [ 4 ] repeatedly for the third digit
    To save the code press the [ AS ] key to accept
    Irmscher Insignia CDTI 130
    May 2008
    Newry
    Thanks for the replies so far folks, but no joy yet again.
    I have followed your instructions but it refuses to move off SAFE to give the option to enter my code. Would it have anything to do with the fact that it was in CD mode when the battery was disconnected? I can hear a CD rattling around in it when I switch on the ignition but it won't eject and will I have to get a knife out to remove it first? I tried disconnecting the battery again but same thing happening.
    Engine : 2.2 Direct
    should have nothing to do with you having it in CD mode...
    WGAF#5
    have you attempted to enter any codes?
    if you have then you will have locked it out dependant on how may wrong times = how long you have to wait with the IGNITION ON and radio on (engine does not need to be running)
    May 2008
    Newry
    Hi Deztroyer and thanks for the reply - I havent got to the stage where it asks me to enter a code so I don't think its locked out. I have checked round tyhe net and apparently there should be a number on the left of Safe telling me how many goes I have. But I have no number.
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Make sure the radio is off then do what i said before,switch ignition off then on and hold AS on keep it held down till you hear a beep noise(just try that instead of switch HU on).
    Failing that make sure you follow the instructions below to the letter and if its still wont code you will need to get a radio company to look at it
    Turn Off Stereo
    Switch On Ignition (No Need To Start Engine)
    Press & Hold Preset " AS " and
    Switch Radio On - Display Shows
    " SAFE " And Then Shows " 10 - - - - "
    Press preset " 1 " repeatedly for 1st Digit
    Press preset " 2 " repeatedly for 2nd Digit
    Press preset " 3 " repeatedly for 3rd Digit
    Press preset " 4 " repeatedly for 4th Digit
    If the correct code number is now shown
    Press & Hold Preset " AS " Until the Unit Beeps
    Try HERE FOR DECODE
    May 2008
    Newry
    Thanks Bigmac - I have come to the conclusion that the radio is not switching off for me using the on/off button. I'm gonna try later by pulling out the fuse and inserting it again in the process above and see if that helps.
  1. 2005 2.2 radiator to fit a 2005 1.9 cdti 120bhp
    By IRvectra786 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2012, 08:59
  2. keeping your car keys safe! really safe
    By nicj in forum General Chat
    Last Post: 10th November 2012, 15:15
  3. Safe
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2011, 02:30
  4. 2005 safe mode
    By Inspektor in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2006, 20:49
cdr 2005 safe but no number
