Results 1 to 10 of 16
Thread: Broken Springs, 05 cdti Sri 150 auto, sat nav. 36,000 miles
    WIRRAL
    Default Broken Springs, 05 cdti Sri 150 auto, sat nav. 36,000 miles
    Both front springs broken on a 05 cdti Sri 150 auto, sat nav. 36,000 miles
    Axle weights front 1090 kg back 0985 kg.
    I've just ordered a set of Eibach springs Part Number:10-65-007-02-22
    Front 1061kg to 1130kg, rear up to 1035kg
    Has anyone else fitted Eibach springs with the same axle weights, also did you notice any difference in the car?
    Regular Member Jezzy's Avatar
    S.E
    The difference will be quite apparent I'd have thought - the eibachs will make the car sit 15mm lower than SRi springs, which you'll notice during cornering.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    It seems though that some Vectra's sit differently with this weight of spring on the front - some look the same, some a bit lower and some higher - don't expect it look like its been dropped, but it will handle much, much better.
    WIRRAL
    It should handle better great!
    I thought the springs would lower the ride height by 15mm ( Not a big drop) but I'm more worried that the front might ride high compared to the rear. Has anyone had these springs fitted with the same axle weights ?
    WIRRAL
    Springs arrived this morning.
    Hopefully going to fit them on sat. It'll be nice to get the car back on the road.
    WIRRAL
    Default Do I need to fit plastic sleeve's
    Do I need to fit plastic sleeve's that slip over the springs as I'm fitting Eibach springs, or is it only on vauxhall's own springs?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by 26alan View Post
    Its best to do it regardless of what springs you have mate.
    WIRRAL
    Cheers Dan_BlackSRi
    I'll get some, and fit them at the same time.
    WIRRAL
    Default Thanks
    I'd like to thank everyone, as the information you can obtain on this forum is quality.
    I've now fitted the Eibach Springs.
    Jul 2009
    sussex
    any good?
  1. 1.9CDTi Broken Timing Belt at 69k Miles!!!
    By Vectra-sceptic in forum Engine & Drivetrain
    Last Post: 24th September 2010, 15:16
  2. broken springs !!!!!
    By leebutcher2.8 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 14:25
  3. More broken springs........
    By axelf in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2009, 07:40
  4. 07 XP2 Nav ( Colour ), 19" Wheels, Auto 2.2 17k Miles
    By ccsnet in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 9th January 2009, 14:10
  5. Broken springs
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2006, 21:16
