Results 1 to 10 of 11
Thread: CD70 navi radio code
    Aug 2009
    north wales
    Default CD70 navi radio code
    i have a CD70 navi headunit which isnt standard fitted in my vectra will the radio code be matched to car or headunit?? if head unit anyway i can find it out if dont have it??
    They are coded to the car and need unpairing from the car they came from and putting into a transport mode/delivery mode. I imagine some places may be able to sort it if they haven't been unpaired but its probably costly, other than that it may be an expensive door stop.
    If yours wasn's spec'd with sat nav then its not even as simple as that.
    Aug 2009
    north wales
    i got the car with the headunit, and am going to have to remove headunit to fit a parrot handsfree kit so could do with knowing if the code that i got is going to work when re-fit the head unit
    Aug 2009
    north wales
    ive found the radio code on the little card from vauxhall dealership with all the info chasis number, key number etc, will this be the radio code for the car if the headunit has been changed to a CD70 navi, not sure what was in the car from factory??
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    maybe a call to the dealership to find out what was in the car when first leaving factory ....i.m sure they will have the details .....as it is in the car and i assume working it has been paired up to the car ..
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Does the CD70 have a code , mine was removed for the smd conversion and then refitted without the need for a code
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    The CD70 and CID are paired together they are not paired to the car,normally when someone fits a different head unit in they use the immobilizer code as its easy to remember if everything is paired with the one code.This is where people think its coded to the car but in fact you can use any code to pair them together.I have used a different code to pair my HU & CID together but in your case if your just removing the head unit and putting it back in then you will not need the code !
    The only time you will need the code is for when you either sell both or you want to replace a faulty unit or for some strange reason one or both lose there code.
    Irmscher Insignia CDTI 130
    Aug 2009
    north wales
    ok, so if remove to fit a parrot kit then replace staright after i wont need the code?
    just checking ive understood ure post correctly??
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by lloyd_456 View Post
    That is correct
    Aug 2009
    north wales
    thanks pal, appreciate the help and quick response
  1. Replies: 6
    Last Post: 3rd March 2013, 17:36
  2. Security code on CD70 Navi
    By Largespanners in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2009, 16:53
  3. CD70 Navi Radio Update Software 10/2007
    By plasma in forum Parts for sale
    Last Post: 23rd December 2008, 21:39
  4. CD70 Radio code
    By bgm46 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2008, 02:14
how to pair cd70 navi
opel cd70 navi code
code cd70
cd70 code
cd70 radio code
how to enter the code into a cd70 navi
where ro find code on cd 70
how to pair vectra head unit
vauxhall astra h radio cd70 navi code generator
cd70 navi radio
vauxhall navi 70 passcode
radiocode astra cd70
cd70 navi o radio
vectra c radio removal code
will i need code vectra c radio refitting
radio code generator
cd 70 navi
cd70 navi in different car
cd 70 navi code
do I need the radio code to remove cd70 navi
cd70 navi code
cd70 how to get radio codr
opel cd70 code
cd70 navi
Do I need a radio code for 2006 vectra
