Thread: Brake Light Check
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Default Brake Light Check
    I know this is a strange one, but can everyone chech their brake light plse. 2 people needed to check brake lights unless you are clever.
    I followed a C tonight 04 plate, the brake lights were brighter than mine.
    On the rear lights at the top are the Indicators (clear or orange)
    On my 53 GSi the brake lights and side lights are in the 2nd set of lights with another pair of side lights in the 3rd set on there own
    On the C i followed the brake lights were brighter and larger in the 3rd set of lights with side lights.
    I then saw an 07 plate and again the lights on that were the same as mine with the brake lights in the 2nd set.
    Maybe his brake lights had blown so it just used other lamps?
    Berinsfield,Oxford
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    I had thought about that Sig but they were a lot brighter than mine.
    All of the lamps in the rear clusters use 21w bulbs so really its only the cars ecu that changes the outputs unless the owner had altered it some way. Although the early ones, if braking very hard - abs cuts in - then it does make the brake lights brighter to show up more in an emergency situation.
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    halford doing hight intensity brake light bulbs i bought them for mine do make them brighter this may be what you seen
    Regular Member garvey's Avatar
    Co Durham
    It's running on its aux brake lights. they are much bigger and i think look better
  1. what can cause a brake pad check light to appear randomly?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 17:42
  2. Check Right Brake Light
    By Dobs in forum Engine & Drivetrain
    Last Post: 20th October 2012, 09:13
  3. Check Brake Light
    By gavmckay in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2012, 11:15
  4. Check brake light switch
    By dolf.peeters in forum Engine & Drivetrain
    Last Post: 5th July 2011, 00:55
  5. Check rear brake light.
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2007, 20:04
brake light check opel vectra
vectra brake light check rear
https:www.vectra-c.comforumshowthread.php93762-Brake-Light-Check
