Results 1 to 10 of 16
Thread: ESP problem
    Oct 2009
    Egypt
    Default ESP problem
    hello guys
    I have 2008 Vectra C and the dealer who sold me the car said that is has ESP but i feel that it's not installed in the car, because there is no switch and no indicator flashes when I drift with the car.
    now I want to know how to make sure that it's installed??? is there any device under the hood or something i should look for???
    thanks for your quick help
    damasry
    i will guess you mean ESP. Not many 2008's have this or traction control at all, only as an extra on most engines. I would have thought it will have its own fuses/relays that you could check, although i don't know which ones.
    Oct 2009
    Egypt
    sorry for the mistake , yes i meant ESP.
    the car has TC because the indicator flashes in the dashboard.
    but i want to make sure the my car has ESP as the dealer told me.
    Oct 2006
    Wellingborough
    In the UK i'm pretty sure TC was a part of ESP, certainly on the facelifts - so if you have TC you have ESP. If you're looking for the more advanced system it is CDC, Continuous Damping Control, which is a further extra. That should be failry obvious to identify, as your shock absorbers would have power/data connectors going to them.
    What about the esp+? why are there so many different terms for the same stuff
    Oct 2006
    Wellingborough
    I believe ESP+ is just the name - i.e. there isn't ESP and ESP+, just ESP+.
    Yep your right, Tc and then ESP+
    Although there was a difference between the esp+ and CBC, although they look the same to me!
    https://www.gmproductforum.co.uk/articles/2213.pdf
    page 14
    edit: I understand now
    or the OP, its all on page 74 of that link
    Mileage : 000
    Quote Originally Posted by damasry View Post
    I doubt it that you have ESP. But if you look on the label on the ABS module there should be the words ESP writen there. I have a 3.2 V6 where ESP was standard, and I have the words ESP writen on the label, as mentioned.
    Oct 2009
    Egypt
    is there any light indicator that lights when the ESP work???
    The traction control light flashes iirc
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
