Results 1 to 10 of 19
Thread: Very Strange...Spanner Light
    East Midlands
    Default Very Strange...Spanner Light
    Just Changed the oil and fuel filter and nothing else has been done,filled up with fresh oil went to start the engine and on comes the spanner light,even i can't fathom this one...anyone got any ideas???
    Full Member Big Sig's Avatar
    Did you accidently knock a sensor plug off or something?
    East Midlands
    Don't think so m8'just checked round engine bay and can't see anything obvious.
    Sorry, out of ideas then have you tried the pedal trick to read the fault codes? Its on here somewhere if you search although I haven't tried it myself.
    East Midlands
    No never heard off the pedal trick
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    did you have ign on when you changed fuel filter ? is the water sensor on bottom of fuel filter connected or heater element on top plugged in forgot to ask is it diesel or petrol?
    East Midlands
    Quote Originally Posted by paul wingnut View Post
    Thanks for reply paul.
    Q .did you have ign on when you changed fuel filter ?
    A.Don't know if i did or not...?would it make any difference
    Also, is the spanner on when the engine is running or did it go out.
    I think that if you turned the ign on when it was out of oil then is it possible that the low level would cause a fault light?
    East Midlands
    No the spanner is on continously when engines running,just had a look at the pedal method to check any codes but unfortunatly don't work on my car/
    ?Is there a chance that if i disconnect the battery ,it might go out.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Spanner light very strange...
    By fast_esi in forum Engine & Drivetrain
    Last Post: 27th July 2011, 21:26
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. Spanner Light and strange smell!!
    By neil1194 in forum Engine & Drivetrain
    Last Post: 9th February 2008, 20:42
