Results 1 to 10 of 16
Thread: Yesssssssssssssssss
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default Yesssssssssssssssss
    YESSSSSSSS no more noise from the front of the car, i changed my ARB bushes today and there was only about 1mm difference between the new on and the old one (same part number) so i changed them both (with help from the how2) 4 hours later noise has gone.
    i would recommend the torx12 spanner tho its make the job alot easy,
    Full Member Big Sig's Avatar
    Regular Member signum03's Avatar
    worthing
    i know the feeling of that happiness, its unreal how a small part can cause so much noise.
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    what kind of noise were you gettting chris
    Oct 2009
    Sandwell
    Quote Originally Posted by tangoman View Post
    it was the sort of creaking / grinding sound when going over speed humps, cant say i had knocking it was creaking , like the bottom of the car as scrapping on the road when going over hump
    Regular Member bigbnlr's Avatar
    Belfast
    sounds like i need these done too
    Oct 2009
    Sandwell
    im gonna give the back ones ago tuesday, does anybody no if there is also two sizes for the back or are they the same part number as the front?
    worthing
    different part numbers for back, just buy 2 for rear they are same parts!
    Oct 2009
    Sandwell
    Quote Originally Posted by signum03 View Post
    the ones that fit on the front are the same for the back????
    sorry just read the how2 for this they look different, when i ordered the two sizes for the front i aint opned the other size do ya think vx will have them back??????
    worthing
    i will double check whats the part number of the one you pair you bought for the back?
