Does anyone know the part number for part 9 bellow
Thanks in advance.
Thanks in advance.
unfortunately I don't but I imagine if you take that picture to a stealers they'll be able to look it up for you.
Mine was broken and they found it no problem at vauxhalls.
Only a few quid
Have you checked to make sure you have the two compression rubbers that stop the parcel shelf flapping about when the tailgate is closed?
Not shown on your diagram but they clip into the tailgate on either side.
Jon
i'll have a look later, but was at the stealers this morning for a part that was broken by the mechanic when i was getting my rear washer fixed, and asked him about the rubber and was told they don't do it it comes as complete with the parcel shelve, i dont think this is true, the guy was a bit of an idiot not very helpfull at all looked as if he didn't want to be there.
Vx 13184638 or Op 23 45 992 - Bumper, Rubber, Load Compartment Cover - 2 per veh
cheers mate, i'll try parts again at the stealers and quote the part number.
you know the two end on the shelve that connect it to the sides one of mine have snaped so mine rattles, do i need to get a complete shelve
Ok, going by your description and a look at my own parcel shelf, I'm assuming you mean the plastic 'socket' part of the hinge. EPC lists these as :
Vx 24466027 Op 73 45 505 - Support, Load Compartment Cover, Front LH
Vx 24466028 Op 73 45 506 - Support, Load Compartment Cover, Front RH
Each is attached to the main cover (shelf) by two screws from the underside.
Your local stealer should be able to give you a price but I can't see them being much.
