Results 1 to 10 of 15
Thread: Parcel shelf rattle
    Sep 2009
    Glasgow
    Default Parcel shelf rattle
    Does anyone know the part number for part 9 bellow
    Thanks in advance.
    Edinburgh
    unfortunately I don't but I imagine if you take that picture to a stealers they'll be able to look it up for you.
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    Mine was broken and they found it no problem at vauxhalls.
    Only a few quid
    Have you checked to make sure you have the two compression rubbers that stop the parcel shelf flapping about when the tailgate is closed?
    Not shown on your diagram but they clip into the tailgate on either side.
    Jon
    Sep 2009
    Glasgow
    i'll have a look later, but was at the stealers this morning for a part that was broken by the mechanic when i was getting my rear washer fixed, and asked him about the rubber and was told they don't do it it comes as complete with the parcel shelve, i dont think this is true, the guy was a bit of an idiot not very helpfull at all looked as if he didn't want to be there.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Vx 13184638 or Op 23 45 992 - Bumper, Rubber, Load Compartment Cover - 2 per veh
    Sep 2009
    Glasgow
    cheers mate, i'll try parts again at the stealers and quote the part number.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    you know the two end on the shelve that connect it to the sides one of mine have snaped so mine rattles, do i need to get a complete shelve
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by chris1804 View Post
    Not sure which part you mean. No idea of availability either, sorry. But if you can ID the bit you're after (is it shown in the OP's picture?) I'll see if I can find a part number for you.
    Oct 2009
    Sandwell
    Quote Originally Posted by Handyandy-UK View Post
    you know the two hinges 1 on each side that make the shelve move up and down (the ones at the back each side) one of mine have broken, so its keeps banging , the yello arrows are where they are ment to go,
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Ok, going by your description and a look at my own parcel shelf, I'm assuming you mean the plastic 'socket' part of the hinge. EPC lists these as :
    Vx 24466027 Op 73 45 505 - Support, Load Compartment Cover, Front LH
    Vx 24466028 Op 73 45 506 - Support, Load Compartment Cover, Front RH
    Each is attached to the main cover (shelf) by two screws from the underside.
    Your local stealer should be able to give you a price but I can't see them being much.
  1. Parcel shelf rattle
    By pipamish in forum Bodywork & Interior
    Last Post: 17th February 2012, 12:24
  2. ANNOYING rattle from parcel shelf
    By amand in forum Bodywork & Interior
    Last Post: 4th November 2011, 20:20
  3. parcel shelf rattle
    By STU3667 in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2011, 18:46
  4. Parcel shelf rattle
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2010, 23:06
  5. Parcel shelf rattle
    By PeterVV in forum Bodywork & Interior
    Last Post: 6th November 2010, 22:29
vectra c parcel shelf rattle
