Thread: cd30 aux connection io connect
    Oct 2009
    Renfrew
    Smile cd30 aux connection io connect
    Been searching the internet for the answer to this question. Which I hope may help some one else. Eventually bit the bullet and bought the io connect. Hope this thread helps someone else trying to connect an aux connection to cd30 (infrerior stereo) so they can play music from ipod, mp3 or phone.
    I have been reading lots of threads and have been trying to figure out how to use ipod with my cd30 fitted in my Vx vectra c 2007 1.9 CDTi Sri.
    After lots of reading it appears there is no way to fit an aux connection into the stereo witout alot of problems.
    I have just bought and fitted an io connect and sot-122 lead from www.nexxia.co.uk for 60 quid bargain in my opinion.
    This is for the info of people trying to connect there ipod or phone to the cd30 so they can play their music. It works a treat so far. The sound is excellent.
    Positives - Excellent sound quality, io connect is a 60 watt amp.
    Negatives - Can only control volume from device attached, along with music selection. They radio controls are defunct along with the steering controls.
    Fitting - Easy enough even for a novice like myself. Hardest part was connecting the ignition fed power supply to the 12v connection next to the ashtray. Took about 1 hour and 30 mins to fit.
    Hope this helps someone out there.
    Sri CDTi is the dogz. Now that I have good tunes.
    Cheers.
    Feb 2006
    Dorset
    Best place for the cd30 is either the bin or a door stop !
    im using a cc9060 bury kit with a kenwood usb headunit and a pioneer "the pump" linear bass tube and it sounds pretty damn good ! i can play music from my blackberry via AD2P
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    CD30 isthe only Vx unit that lists the Aux-In connections.
    CD30 is quite basic, but the most reliable of the Vx units.
    For the price of any Vx head-unit, you could get a decent after-market sat-nav, dvd playing, touch screen double din head unit with ipod / mp3 input, usb or sd card input all built in.!!!
    Down to your own personal choice / budget!!
    Jul 2009
    london
    when you say "CD30 isthe only Vx unit that lists the Aux-In connections." - what do you mean ? - has CD30 got an AUX in or not
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    It has connections for using aux-in, but you may need Tech 2 to activate this.
    I've never tried, but a lot of literature identifies that this IS the case.
    If you pull out the radio, and look at the pin-out sticker...you will find mention of 3 pins
    RSA R, RSA L and RSA -.
    Not certain, but believe that these may be your Aux-In.
    Ammendment to my post above: -
    The CDC40 Opera's have inputs for a DAB unit, when this is not fitted, the the audio input pins can be used for Aux-In instead.
    This is separate from the Ext-In which is used for SOT driven phone kits etc.
    (Or so it is alleged in TIS - vauxhall Technical Manual, however I have found one or two errors with TIS over the years!)
  1. Fitting Parrot MKi9200- Can it run through CD30 aux?(does CD30 even have aux!?)
    By dibble750 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2013, 02:20
  2. AUX connection into CD30 Headunit - Vectra C
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2012, 07:45
  3. Ford connect help
    By aerodynamic18 in forum The 'Off Topic' room
    Last Post: 5th November 2009, 10:43
  4. cd30 aux connection io connect
    By Davyboy30 in forum Introduce yourself.
    Last Post: 16th October 2009, 22:57
  5. Ways to connect an Ipod to a standard CD30...
    By Jim Bob in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2008, 11:48
connect RSA CD30
