Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Dash lights
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default Dash lights
    i have just noticed that the four buttons around my headlight switch are not lighting up although the headlight switch itself does light up,does anyone have any idea`s what the problem might be an how it may be fixed?
    grimsby lincolnshire
    Hi they will only light up when you have your headlights on. hth
    Derry
    Hi m8,no only the main headlight switch will light up,the other four buttons around it are not.
    Derry
    Does anyone else have any thoughts on want the problem maybe,like a bolwn fuse etc?
    Full Member Big Sig's Avatar
    If you turn the light switch to the middle setting - assuming you do not have auto lights, and push it in it allows you to remove the switch. make sure its plugged in correctly, or even try someone elses unit to see if theirs lights up
    Derry
    Do you mean the main light switch,do i need to remove the small strip of the dash 1st before i remove the whole switch section?I thought all the buttons on this small panel would be illuminated from the 1 scource.
    yes the main light switch. the trim above does not need to be removed iirc
    They probably have 4 small smd's - leds. one each
    Derry
    It seems strange that the 4 smaller buttons dont light up tho when the main one does,are they hard to replace,or could it be a fuse?
    I don't think they are fused. Best thing is to pop it out and have a look at it, incase its something easy
    Derry
    Thanx Sig for the info,i will take a look when the wife comes back with the car,do you no if they are hard to replace?
  1. Dash lights
    By stuk2000 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 21:51
  2. Dash lights
    By Rudy in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2013, 17:58
  3. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  4. Dash Lights???
    By dave04 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2010, 15:32
  5. Dash lights?
    By Messenger in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 21:29
