Results 1 to 10 of 13
Thread: Pedal test
    Regular Member yadziyad's Avatar
    London
    Default Pedal test
    hi,
    the warnig light has come on and i dont know how to do the pedal test can someone guide me please.
    thanks
    Ashington, Northumberland
    Warning light for what mate? What does the light look like? If you can be a bit more specific we'll have a better idea of your problem and will be able to advise you better
    London
    Quote Originally Posted by GARY3306 View Post
    its the dreaded car with spanner light. it comes on every morning for about 15 sec and if i rev over 3k then it goes out straight away.
    Regular Member suggs1971's Avatar
    east cleveland
    My old veccy b did the same, turned out it had a glow plug off. Hth.
    London
    Quote Originally Posted by suggs1971 View Post
    how can i check if its the glow plug where i they located. would it come up on the pedal test, if so how do i do the test.
    thanks
    What's this 'pedal test' that you're on about. I don't think any of the members will have heard of that. As a mechanic myself, the only 'pedal test' I ever carry out is for testing brake servo operation
    London
    i read about it in another thread i think its this one.
    http://www.vectra-c.com/forum/showthread.php?t=89913
    Oh right, well I've never heard of it. Best thing to do is get it on a Tech 2
    London
    its still running at the mo and as things are a bit tight ill wait a bit and just use my almera
    Sep 2009
    Stratford-upon-Avon
    It involves turn the key so ignition is on but not started, whilst pushing down on the accelerator and brake, the lights in the tacho will flash, count the flashes and it give you the fault code, not sure how to decode the flashes, but do a search and it will tell you. The glow plugs only apply if you have a diesel, if so they are under the big plastic engine cover, similar to spark plugs on a petrol...
    hope you get it sorted mate!
  1. pedal test
    By GCusdin in forum Vectra C / Signum Troubleshooting
    Last Post: 1st February 2013, 12:07
  2. Pedal test won't work
    By johp778 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2013, 17:09
  3. done pedal test and
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 26th March 2012, 22:07
  4. Pedal code Test
    By clowe7447 in forum Engine & Drivetrain
    Last Post: 13th September 2011, 07:43
  5. pedal test playing up?
    By TimTay in forum Engine & Drivetrain
    Last Post: 16th August 2011, 11:03
vectra c pedal test
