Thread: A definitive answer please! lol
    Regular Member DTGB's Avatar
    Basingstoke, Hampshire
    rolleyes A definitive answer please! lol
    I am looking to treat my 2.2 (Elegance, yep I can hear y'all laughing) to a set of lowering springs - Gonna go for the Eibach ones. Can anyone confirm that I can use these with standard shocks, or is it false economy & replace them anyway.
    Lastly, who is the best place/Person to contact to do this at a sensible price & do you need a full 4 wheel re-alignment cos' the ride height is altered?
    (Assume camber doesn't need to be adjusted either?)
    Just want to be safe rather than sorry, befor parting with my hard earned cash
    Thanks in advance for your Jedi Vectra knowledge.....
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Yes mate you can use Eibach springs on standard shocks
    Its only when you go to 40 mm or more do you need shortened shocks good luck with getting them post pics when fitted
    Professional Trader LMF's Avatar
    Leics
    Eibachs are fine with standard shocks. You'll need your axle weights for the correct springs.
    rolleyes You guys are legends, thanks!
    Will post a pic once I get them fitted....what about the camber adjustment & 4 wheel alignment? - Surely they need to be sorted so the tyres dont scrub & handling is not scew?
    Ta
    Leics
    Quote Originally Posted by DTGB View Post
    Ta
    You won't have any tyre scrub on standard wheels, as a rule its always best to get your car set up whenever you have suspension work done to make sure everything is as it should be.
    Regular Member Blagmeister's Avatar
    Warks
    I changed my springs over to Eibachs when one broke and am using standard shocks with no probs. I have to say that the handling has improved greatly. I would say though that the ride could benefit with a bit more rebound damping to stop the bouncy effect over undulations. Some B4s would prolly do the trick.
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    i had cobra sport springs-40mm on mmy signum with standard shocks and had no porobs at all mate obviously for ultimate handling you should uprate the shocks but just for looks and good ride comfort id stick too standard shocks hth
    Talking Cheers boys...keep em' peeled for pics soon
    Once again, thanks for your help guys
  1. Definitive answer?
    By dan21 in forum Diesel Engine related
    Last Post: 13th February 2013, 16:38
  2. Definitive answer on stereo and screen swap?
    By Munnzie in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2013, 14:32
  3. Definitive Threads
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2007, 22:47
