Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Blue LED conversion
    Default Blue LED conversion
    I just boughtVectra C LED heater panel conversion kit. and Vectra C LED Speedometer kit from crazy LED. , I now require the LED's for the steering wheel and side door switches, light switches etc.
    from what ive read i require around 20 of RS No. 654-5111 from RS components. Could anyone please confirm. Also im abit confused as to how i would go about putting blue litting on the lcd display mid dash, i.e. where the temp and time is displayed. Mines a standard LS so it does not have trip computer. Could someone please please point out which LED's i would need to convert it to blue. I need to put the order through ASAP so time is of the essence!
    Professional Trader LMF's Avatar
    Leics
    The display is a right pain tbh, we tried to do mine but its not great, but then I have a motorised screen which covers this so it doesn't bother me.
    Regular Member paul.sessions's Avatar
    leighton buzzard
    you can buy the single smd from crazy leds you need plcc-2 for window switches, light switches, speedo clocks.. i needed plcc-4 for the computer screen (36 of them)!
    you need normal 3mm leds for the steering controls about 6 i think..
    chears for the reply mate
    I suppose your screen has a trip on it? mine just displays the time n temp, mines a standard LS, any idea how many plcc-4 i need?
    cambs
    Quote Originally Posted by siz1 View Post
    hi m8 your screen if a tid (triple info screen)
    will have 501 bulbs (3)for the back light same as you side lights
    and the 2 buttons for altering you time not 100% sure but think they are the same as the ones in the doors buttons not sure of part number
    "your screen if a tid (triple info screen) will have 501 bulbs"
    nearly had a stroke then, thought you meant ill need 501 bulbs! but you meant that type, 3 of them!
    do you mean the ones on the first pic here :
    https://www.crazyleds.co.uk/search.p...=search&page=2
    ive already spent £50 on Leds and still require more.. i suppose the end result is worth it!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    £50! Its worth it in the end mate.
    yh i know, but i think it will be around £70 when i finish... ill put pics up when finished along with my new pioneer double din !
    leighton buzzard
    defo worth in the end im lovin it still
    Regular Member david.aka.judas's Avatar
    Suffolk
    they can fit them for you (crazyleds) any one used them?
  1. Another blue led conversion
    By jon1.9cdti in forum Styling
    Last Post: 16th July 2012, 18:43
  2. Blue L.E.D Conversion
    By qrm666 in forum Styling
    Last Post: 22nd November 2009, 19:11
vectra c led speedometer kit
vectra c blue led conversion
