Thread: steering wheel button problem
    london uk
    Default steering wheel button problem
    I have a vectra c sept04 and it had a cdr2005 on .
    About 2years ago i decided to change the cd player and use a jvc kd g731.
    I bought the facia adapter , and autoleads cables pc99-x06 and pc99jvc and after the installation i realised that the forward truck button after 30min of driving and use wouldnt work anymore it would work as mute button.
    So recently i decided to change the cables because they might be faulty ,so i order them again and had them installed.
    When i drove the car and used the button after 30min the button wouldnt work at all.
    I called autoleads and they told me to run the red cable that goes in the black box of pc99-x06 to a separate ingnition switched power supply from the fuse box and that would solve my problem.
    I did that this morning and the button after 30 min worked as mute again .
    Did anyone had similar problem?
    Could someone help please?
    WGAF#5
    could be an issue with the JVC head unit
    maybe you could also send admin a quick email......
    to delete the other 3 identical threads
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    as above, sounds like a headunit fault. i've had a couple jvc's over the years and found as they age, buttons on the unit like "skip track" mute the sound or do some other kind of function. For this reason i aint buying jvc again, but thats only my personal view
    london uk
    Default steering button fault still persists
    today i bought a sony cd player compatible with steering wheel controls and still after 30-40min i had the same problem again.the button that was working fine as forward track it didnt work.
    So now its not a matter of a brand jvc or sony its a problem with the car.
    Any more ideas about the problem please?
  1. Steering wheel controls..button V roller wheel
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2011, 18:18
  2. Steering Wheel Button Surrounds
    By kdadidog in forum Styling
    Last Post: 2nd May 2009, 17:07
