Results 1 to 10 of 16
Thread: Juddering cured, now power loss - obviously a 3.0CDTi
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default Juddering cured, now power loss - obviously a 3.0CDTi
    Hello there.
    My 3.0 is running like a dream now! Injectors not knocking, the engine is not juddering and not smoking.
    However, I have power loss now. It seems there is a lack of boost around 2000-4000rpm. Once passed 3500rpm the engine is gutless.
    Been thorugh a tunnel the other day. Put my foot down in 4th gear (windows down so I could hear the engine) and I could hear the turbo going on/off/on/off and then on again.
    Overall the car performs well, only not as brilliantly as it should.
    There is no visible smoke under any circumstances, be it 2500 or 4000 rpm.
    Is this a case of sticking turbo vanes?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Bump!
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I'm having the catalytic converter emptied of all the soot next week.
    It could be the vanes, boost sensor, actuators........
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I gave the boost sensor a clean when I had the rocker covers off.
    The ........ are reassuring lol
    As we both know its such a mine field when playing with any modern engine
    Sounds like the SCVs on the fuel pump
    You get to about 2000rpm and then it feels like the brakes are being applied
    As it gets worse the engine judders, and the revs lower
    It can be worse uphill making overtaking impossible
    If you take the engine to about 3500rpm then the power returns
    Try my temporary solution of adding two bottle of diesel fuel pump cleaner to an empty tank
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    It's quite the opposite mate. I have a nice kick in the back once over 2000rpm. At no point I feel like the brakes are applied. It only seems that there is no difference if I boot the engine or use 3/4 of throttle... I dare say it pulls better if I use 75% of throttle...
    Last time I put a bottle of injector cleaner to an empty tank it made the car behave like crap...not doing it again...EVER!
    Quote Originally Posted by Celes View Post
    Missed that symptom
    That is EXACTLY what mine was doing
    So that confirms that one of the two SCVs is blocked
    If you read one of my earlier posts you will see I mentioned the turbo could be heard going on / off / on / off continuously
    It's not injector cleaner you want, its diesel fuel pump cleaner
    This is a much thicker liquid
    The instructions are to add one bottle before filling an empty fuel tank
    The liquid settles at the bottom the fuel tank and is drawn through
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Missed that symptom
    Mine has been doing that since I got it back in January. There were times that this seemed to have cured itself, but now it's back
    The injector cleaner is way too agressive of a fluid, therfore I think it does more harm than good. I am using 2-stroke oil and the engine is much quieter on idle.
    If I remember correctly, 1000ish miles after your cambelt change the car started to lose power or having similar symptoms.
    You know what? MINE IS THE SAME!
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. 2L DTI '53 Loss of Power
    By BigTunz in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 17:27
  3. power loss when hot
    By Dougb in forum Engine & Drivetrain
    Last Post: 1st July 2010, 10:35
  4. Loss of Power
    By maninwales in forum Engine & Drivetrain
    Last Post: 26th February 2010, 13:55
  5. Still loss of power!!
    By jonnynufc in forum Engine & Drivetrain
    Last Post: 5th July 2009, 00:07
vectra c 3.0cdti loss of power and some times judders
http:www.vectra-c.comforumshowthread.php93622-Juddering-cured-now-power-loss-obviously-a-3-0CDTipage2
