Thread: cim problem?
    scotland
    Default cim problem?
    hi have had the car at vauxhall and tech2 said that my cim is knackered, i have been reading on here about the abs plug, would tech2 be fooled into thinking it was my cim if it was realy the abs plug? or if not can i by any new cim with a different part number or do they have to be identical?
    thanks for the help in advance
    Bristol
    You can get a new or used sim . If you buy a used sim make sure its facelift or pre facelift. Also make sure it is divorsed from car it was removed from and that the car it came of has esp on it if your car has. if youshas not got esp don't worry. The sim will have to be programed to you car with tech2 that is the only way. I just put a seconhand one in mine and it perfect.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    CIM's are coded to the car mate. If you buy a second hand one it has to be programmed out of the doner as well as programmed into the new one, if not its fubared. If tech 2 gives the codes for the CIM its more than likely the CIM. You will also need a matching CIM, any old one wont work.
    EDIT:
    scotland
    so the part number has to be exactly the same? the part number i need is 13125074 is this part number going to be the same for say on 07 model when mines is an 02 cheers
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No I think there is a 3 letter code that needs to be the same. CIM by plasma he mentions is somewhere.
    scotland
    cim is too short to search, thanks for the help hopefully plasma will see this and reply cheers
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    THIS old thread of mine may help to what you need to know mate.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
