Results 1 to 10 of 17
Thread: Vectra C Front Fog Steaming up
    Regular Member dudley6623's Avatar
    Sep 2009
    skegness lincolnshire
    Trim : SRI
    Engine : 2.0L Turbo
    Year : 04/54
    Mileage : 88000
    Default Vectra C Front Fog Steaming up
    My 54 plate vectra sri has just develoed a steamy/misty front fog light, light still works but looks naff!! glass is not broke so has anyone any ideas or is it just best to replace
    many thanks
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    a pack of silica gell in it will do the trick....btw i guess it is the passenger side one,???
    Midlands Mod Shop - NFFC.
    WGAF#5
    its a known issue
    and you can buy a snorkle mod from vauxhall for the fog light
    Regular Member gibbon7000's Avatar
    lincs
    Do the facelifts suffer from the same problem cos my passenger side is misted up?? I just bought a new one cos I thought it was knackered
    WGAF#5
    Quote Originally Posted by gibbon7000 View Post
    sounds like it may do
    the passenger one normally mists up following filling the incredibly small apeture on the washer bottle neck and spilling fluid over the top of the fog light
    all i did with mine was removed it ans applied shower sealant to the outer edges of the seals - it hasnt fogged up since
    Regular Member @ndy-e's Avatar
    Warrington
    I dont think the Vec is the only one to suffer this problem, seen a 58 plate Astra passenger side fog misted up!
    Regular Member Clugie's Avatar
    Jun 2009
    Liverpool
    I have the exact same problem on a 54 plate veccy, an wots silica gel an we're can u buy it??
    WGAF#5
    Quote Originally Posted by Clugie View Post
    silica gel is the little packet you normally find in the bottom of a box of new shoes - or an electrical product
    it absorbs moisture and then becomes redundant - the packet would then need to be removed and "baked" in an oven to remove the moisture
    so it would be an ongoing issue - best advice resolve the issue (as above) and then you wont have to keep popping silica in the lamp unit
    Jun 2009
    Liverpool
    Is there a how 2 on removing the fog light? If so could someone post it on here because am on me fone at work and It won't let me do a search, thanks in advance
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I just placed a tiny hole in the fog light cover (very small, like with a pin) and put the cover back and its never fogged up since - and with the hole being so small, won't let any water in either (you can get at them on the pre-facelift just by sticking your hand underneath and turning the cover off).
  1. windows steaming up
    By protector in forum Bodywork & Interior
    Last Post: 22nd March 2011, 22:54
  2. front window keeps steaming up
    By vectragsi3.2 in forum Bodywork & Interior
    Last Post: 4th October 2010, 20:27
  3. Headlight steaming up....
    By pgilc1 in forum Bodywork & Interior
    Last Post: 8th November 2009, 20:35
vectra c passenger side widow steam
