Results 1 to 10 of 11
Thread: Alarm & hissy fits
    Regular Member Readster's Avatar
    Plymouth
    confused Alarm & hissy fits
    The alarm on my estate has got more unstable over the past few weeks to the point where I was outside at 0100 hrs trying to get it to stop going off every 5 minutes...
    My temp fix is to remove the 3 rear fuses that for the alarm.
    The LCD is blinking so, there is a fault
    Haynes is about as much use as a chocolate teapot
    Before I surrender to an £80 tech2 at my friends Evans Halshaw, Saltash can I ask you guys..
    - Has anyone found a solution to unstable alarms?
    - If so, what was the problem / issue?
    - was it a home fix?
    Thanks for any advice
    John
    11 Post(s)
    Alarm problems on estate Vectras are more often than not traced to the break wire on the rear window. People either take the relevant fuse out or bridge the wires.
    Plymouth
    Could well be Dave.
    I'll check that the Labradors haven't damaged the glass wires
    John
    Plymouth
    Can't see a break...
    One of the alarm wires on the side windows is discoloured, maybe lifted away from the glass?? but, not broken
    Has anyone encountered this before?
    John
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    I thought you might have a dog ...I did a search and someone found although the wire wasn't broken it was actually shorting out ,thuis setting off the alarm .he bridged the said wires and hasn't had any probs since
    Plymouth
    I guess you would need a volt meter to measure the glass wires to find the fault. I cannot see a break with the naked eye
    Frustrating...
    Regular Member old cruiser's Avatar
    slough
    Might be worth checking the bonnet switch also mate, they were notorious for playing up on the Omega, might be the same with yours.
    Cheers Pete
    Plymouth
    ah...thanks mate, I'll check that out.
    Didn't think about that sensor I must admit
    slough
    Quote Originally Posted by Readster View Post
    No probs mate, just thought it might be worth a look , you never know.
    Cheers Pete
    Regular Member Factory Pilot's Avatar
    Leics
    I was searching for this thread last night, it may not be a break on the glass, more a contact has fallen off the glass. A possible taking your rear interior side panel bits out to expose the lower section of the glass might spot if it is this problem.
    And it's fuse 23 for the rear alarmed glass, although then you have to put up with 'Safeguard' everytime the CANBUS checks the car over (as i'm sure your probably already aware of).
  1. What else fits?
    By bbdp in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2013, 18:31
  2. Is it just the SRI bumper this fits
    By Angel1368 in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2013, 22:22
  3. What exhaust fits ?
    By DANNYGRAY in forum Engine & Drivetrain
    Last Post: 3rd June 2012, 15:38
  4. what exhaust fits
    By triple595 in forum Petrol Engine related
    Last Post: 10th April 2011, 10:00
  5. Retro Fits
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2009, 17:48
