Results 1 to 10 of 16
Thread: Engine Temperature Gauge - Issue or Not??
    Oct 2009
    Hertfordshire
    Default Engine Temperature Gauge - Issue or Not??
    Hi,
    I have a 2006 1.9cdti and i can't remember ever seeing the internal engine temperature guage ever moving. It always sits on the line and does do anything. Should this be showing some kind of temp or only when over heated????
    I have no idea if this is a fault or not
    Would appreciate some help
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Does it not even move slightly..?
    If it does (but only a bit) then it could be a thermostat fault, but if it doesn't move at all, then it could be an electrical fault to the guage.
    Oct 2007
    Shropshire
    Mine goes up to 92 degrees as it warms up and never moves untill you turn it off. Never seen it even get hot on a hot day in traffic!
    Oct 2009
    Hertfordshire
    Well it it moves backwards when going down a hill but thats about it really. I guess the guage is broken, or possibly a fuse blown???
    Oct 2009
    Hertfordshire
    Right I have just done a test, driven down the road and back (about 4 miles), the temperature guage sat on the line there and back, then parked and switched off and then back on again, it went to 80c straight away and then back to the line. Any ideas?
    Bradford
    Trim : Elite Auto
    Engine : 2.2 Direct Petrol
    Which 'line' are we talking about?
    Oct 2009
    Hertfordshire
    Sorry i mean the zero line, or basically if the car was switched off there gauge would be sat on the white line. Sorry struggling to explain it, hope that makes sense though
    Regular Member djr69uk's Avatar
    Midlands
    the guage starts to move on mine after about 5-10 miles depending on traffic and speed. then it heads towards 90 and stays between 80 and 90 for the duration of the journey.
    if yours isn't moving then sounds like a faulty sender to me..?
    Bradford
    Trim : Elite Auto
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    sender or your thermostat is knackered bud
  1. Engine temperature gauge
    By ridgers84 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th February 2012, 17:08
  2. Engine coolant Temperature gauge highest readings you have had?
    By hertscol in forum Engine & Drivetrain
    Last Post: 10th April 2011, 01:03
  3. temperature gauge
    By chrisknights in forum Bodywork & Interior
    Last Post: 16th February 2011, 23:42
  4. Unusual Temperature Reading From Engine Temp Gauge
    By mikebeasley in forum Engine & Drivetrain
    Last Post: 1st January 2011, 19:43
  5. Engine temperature issue - is slightly over 100degrees correct?
    By djbobeb in forum Engine & Drivetrain
    Last Post: 11th July 2008, 18:44
