Thread: 288mm instead of 285mm
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Default 288mm instead of 285mm
    Do you guys think a 288mm disc will fit my stock (285mm) Vectra C CDTi? I have a pair of 288mm discs, brand new, lying around. Assuming everything else is ok, measurements speaking, do you think it will fit?
    Regular Member david.aka.judas's Avatar
    Suffolk
    looking at the 285mm disks - can you see if you have enough cleanrance from the top of the disk to the caliper?
    if you have - fit them and then check the pads are rubbing on the right part.
    that would be my answer.
    [Ex]Admin Duncan's Avatar
    As Judas said, you need to see if there is clearance from the edge of the disc to the caliper as well as them being the right thickness (the discs).
    If in doubt, leave them as they are.
    Regular Member Jezzy's Avatar
    S.E
    Don't forget that the 288's will have 1.5mm extra radius - all of which won't be in contact with the pads, which means it'll turn into a "lip" as the disk wears down.
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    I don't think they do mate. I had a 288mm set up on my Astra and had to get new calipers and so on. Would be lucky if the discs fit in standard calipers.
    The whole set up did fit ok under 15" rims so you'll be ok in that respect.
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    I think I'll give up the idea. The discs on the car aren't that bad, in fact they are not bad at all. I'll try and sale the 288 discs and maybe get a Goodridge braided hose kit. I always wanted to try something like that.
  1. 285mm up to 314mm discs?
    By lee gsi in forum Suspension, Wheels & Brakes
    Last Post: 15th March 2012, 18:46
  2. For Sale: 285mm calipers, carriers, discs, pads
    By shb1988 in forum Parts for sale
    Last Post: 3rd November 2011, 13:24
  3. SRI 285mm calipers in red
    By parsco in forum Parts for sale
    Last Post: 24th January 2009, 21:32
  4. FREE - 285mm brake set up...
    By danBoy in forum Parts for sale
    Last Post: 11th November 2007, 14:04
