Thread: Somone who knows there vectra electrics give me a small hand? :)
    Oct 2009
    Reading, Berkshire
    Default Somone who knows there vectra electrics give me a small hand? :)
    Hey peeps
    i recently brought a push start button for a 10er from ebay, just a nice little touch i think and it said its easy to install, and from the instructions it does sound pretty damn easy.. no cutting wires or anything just these strange clips that connect wires, it comes with full instructions that are easy enough but beacuse its universal its not specific to any car
    my question is, i have to acess the wires from the ignition barrel how the hell do i get to them??? all it requires you do is use the clips on 2 wires that go from the ignition barrel to the starter solenoid then attach some other wires to the ciggy lighter power (which im sure ill manage) and then fit the button
    heres the item if you want to take a look http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    Admin plasma's Avatar
    On the Forum
    323 Post(s)
    Engine : 150
    Mileage : 74000
    basically its just shorting 2 wires together on the ignition switch. Not sure how much of a 'switch' it is these days on the CIM/steering column. 40amp relay would have been to provide power to the starter solenoid although that method is no longer used these days. You'd still need the key in the ignition and turn the ignition on before you could use the button.
    My personal opinion is it would look tacky in a standard veccy unless its stripped out and rollcaged.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Oct 2009
    Reading, Berkshire
    I know, but i just think it would be a nice touch, and its not a switch just a nice little red button the button itself is quit small and flat so it flushed along on the panel and it just fits on one of the squares parralelle to the radio which is where its going, yeah a relay is provided id to install it i just need to know how i get to the ignition barrel wires?
    On the Forum
    323 Post(s)
    Engine : 150
    Mileage : 74000
    When i find a bit of time I'll take the cowling off and have a quick look for you and see how practicial it is to do. You'll probably wont even need the relay at all.
    Oct 2009
    Reading, Berkshire
    ah great thanks, but the whole wiring loom is alredy done with the relay attached
    Oct 2009
    Reading, Berkshire
    Just took a look myself to see if i could get in there but no luck, as its kind of inside the steering wheel colum i cant get to the wires, im assuming this is where im meant to be acessing them from? (from inside the car?)
  1. Anyone in Plymouth want to give me a hand with my inlet manifold?
    By Innes in forum South West - RO (vacant) / ARO - (dave234)
    Last Post: 21st August 2011, 11:55
  2. Vectra C towbar electrics help
    By zipolly in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2011, 16:09
  3. I'll give the first person 10k for any Vectra!!!
    By lgtuk in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2011, 18:29
  4. could someone give us a hand
    By i5aces in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2010, 10:01
