Thread: clutch/dmf
    manchester
    Default clutch/dmf
    do you really have to change your DMF when changing your clutch many thanks.its a 2.2 direct on 54plate
    Ashington, Northumberland
    Well if it's fine then no you don't HAVE to, but if it's all stripped out for the clutch to be done, it might be worth doing the lot given the history of these things. I've just had to do one on an LDV van at work and I got the conversion kit to change it to a solid flywheel. No such animal for the Vec though I'm afraid
    Edinburgh
    I think it's the other way round you're thinking of rick. If your DMF is duff and you replace it then you should replace the clutch too I think but if you're just changing the clutch and your DMF is fine then it doesn't need changed.
    manchester
    cheers guys,will just change the clutch
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
