Results 1 to 10 of 11
Thread: Sony P900 help
    N.Wales
    Default Sony P900 help
    hey guys, i know it's a car forum, but i'm hoping somebody can help out on this one.
    I've just had a Sony P900, phone works brilliantly... installed the PC suite but can't get the damn thing to Sync.
    Can't get the PC (or lappy) to see the phone... anyone had this problem before?
    Regular Member Ian's Avatar
    York
    Have you installed microsoft active sync on the PC?
    N.Wales
    i've got active sync installed... but as far as i'm aware the P900 doesn't use active sync. instead it uses it's own software package - Sony PC Suite.
    i have installed that, but cant get it to communicate with the phone... damn thing!
    Regular Member Barbara's Avatar
    Jan 2006
    Berks
    Default hm
    I'll help you tomorow when I come back from work, because I had the same problem with my P910i
    Nicking Ya Dinner.
    Look at you, fancy a date?
    Regular Member installer's Avatar
    Nottingham
    My P910i was a pain and still the phone is buggy with latest software on.
    Turned out to be USB connection not allowing to sync,can`t for life of me how I sorted it
    Jan 2006
    Berks
    Quote Originally Posted by Phatty
    I bought my P910i over 1 year ago and after loading the PC Suit I just could not sync my phone with the PC despite trying everything. Then I found out that the driver for the cradle had not been loaded when you install the PC Suit. You need to manually do this. !
    You need to put the PC Suit CD in the PC and then go to your control panel and go to System and look for harware config. You should find the syncing cradle as one of the items there with a yellow question mark (you must have connected the cradle to the PC first). It means there is prob with it. Right click on it and select install driver and then choose from the CD-Rom. it should load up fine from there and .. You are syncing. Some how when you install the PC Suit it does not install the driver ;[
    or
    You can turn off your firewall, because PCSuite wants some MFC application to act as server.
    I really hope this works for you lot.
    Quote Originally Posted by VauxVeteran
    N.Wales
    hi barbara.
    Thanks for your help, but unfortunately i have already tried this and it doesn't work.
    i don't actually have a sync cradle with my P900... only a USB Data Cable - Which i am told will do the job.
    i'm stuck now, i'm just about to download the latest version of PC Suite to see if that helps.
    N.Wales
    just to let you know, it's all sorted now...
    i downloaded the latest PC Suite and hey presto... worked straight away!
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    I solved the problem by going to a nokia, tried for weeks with the sony one. gave up in the end
  1. sony/ mfd
    By m1ke823146 in forum Electrical & ICE (including SatNav)
    Last Post: 10th September 2009, 07:24
  2. Sony Ericsson P900
    By Phatty in forum General items for sale
    Last Post: 13th August 2006, 20:41
  3. Sony With AMP&SUB
    By payney in forum ICE Gallery
    Last Post: 24th July 2006, 16:49
  4. Sony NW-HD3
    By bruceybonus in forum General items for sale
    Last Post: 23rd July 2005, 15:15
