Likes Likes:  1
Results 1 to 10 of 15
Thread: Under seat cable
    Oct 2009
    Falkirk
    Default Under seat cable
    Hi all new to the site. I have a Vectra C Elite and have just had a small problem with the car tonight. I went to move the seat back and there was a snapping noise from underneath the seat so i looked under the seat and seen the wire to move the seat back and forward has snapped. The leaver for moving the seat just goes up and down now and the seat doesn`t move. Any ideas on how much this will cost to replace and how easy it is to fix?
    Thanks guys
    WGAF#5
    Quote Originally Posted by Duffy86 View Post
    Thanks guys
    hi Duffy - if the cable has snapped then hopefully you would be able to match the colour coded cables together and use raychem (heatshrink connectors) to rejoin the cables and hopefully this will resolve your issue
    remember to disconnect the battery before you start playiung with the electrics though - you dont want to blow any motors - or air bags
    if you dont want to do the work yourself then a "good" auto electrician should be able to do the work in an hour including removing the seat
    regards
    Dez
    Mileage : 000
    Dez. I think he means the wire cable that "unlatchs" the seat so you can move it back and forth. Not the electric cables.
    WGAF#5
    Quote Originally Posted by ed taylor View Post
    in the words of homer simpson .....
    Oct 2009
    Falkirk
    yeah sorry not the electrics
    WGAF#5
    i would be surprised if the seat cable system is not available as a separate part :-
    we have a specialist upholstery repair site locally - who would remove the covers and fit a new cable (probably rivetted on) (normally £40-80 dependant on the seat and what is involved)
    might be worth your while doing a Yell search for your area for a local repairer
    Oct 2009
    Falkirk
    got the part was only 6pound odd so will get it fitted tomorrow.
    New Member STANLEY's Avatar
    Jan 2010
    West Midlands
    Default Duffy86
    Hello duffy just seen your message about when your seat packed up with the cable snapping same thing happened to me could you tell me where you got the cable from and was it easy to fit or did you have to get some one to fit it for you oh and do you know the part number too. thanks.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is it just a bit of round metal wire?
    Could a metal coathanger be straightened out and then ends bent over etc to connect the handle to the latch?
    Regular Member vectrinha02's Avatar
    Sep 2016
    Lisbon
    Trim : c
    Engine : 2.2
    Year : 2002
    This happened to me too,
    anyone knows what the part number of this cable?
    Is it easy to fix without remove the seat?
  1. Drivers seat cable.........
    By mantav8 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 07:24
  2. Renewing seat adjustment cable
    By Tigerfan in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2010, 18:55
vectra c seat adjustment cable
vectra seat adjustment cable
https:www.vectra-c.comforumshowthread.php93478-Under-seat-cable
vauxhall vectra seat adjustment cable
vectra c seat cable
seat adjuster cable easy fix vectra c
drivers seat movement on vectra cvectors c seat cablevauxhall vectra seat movement cablevectra c seat cable removalhow does vectra driver seat up and down workvauxhall vectra cable under seatvectra c seat cables setvectra c drivers seat cablevectra c driver chair vectra ajustable seat cabledriver seat mover broke on vauxhall vectravectra c drivers seat falls backvectra c moving seat cablevectra seat cable snappedfixin seat adjuster on vectravectra c front seat adjuster cablevectra c drivers seat adjustment cablevectra forward and back seat adjuster not workingcable to adjust front seats vauxhall vectra
