Thread: Cam belt+water pump?
    Sep 2009
    Consett County Durham
    Vehicle : 52 Vectra c LS 1.8
    Default Cam belt+water pump?
    Hi,I understand that it is correct to replace the water pump as well as the timing belt,is this really necessary. Vectra C 1.8 coming up to 40,000 miles.Regards Martin.
    Sunny Dartmoor
    Yep,had mine replaced back in January,cambelt kit £70,water pump £25,there is a How2 on here aswell.........
    Near Warrington
    Saves a lot of hassle in the future m8,n 4wot they cost there,s no point in leaving it...
    Basically in order to change the water pump you have to remove the cambelt anyway, as it's driven by it. if the bearing in the pump goes you risk trashing the entire engine, so it's a false economy NOT to get them done together...
    Regular Member Boy Lard's Avatar
    Derby
    Not neccesary no but worth doing as a precautionary measure. If the pump fails the belt'll need changing again.
    Dammit - too sloooooow
    Sep 2009
    Hi,Thanks for the info will definitely get the water pump changed as well.Regards Martin.
    Regular Member barkzz's Avatar
    I ahd my cambelt done on my old 1.8 by an independant, but he didnt mention the water pump.
    Pump strating rattling about 2 weeks later, as the bearings were obviously seizing up. Had to get it back to him ASAP for him to replce water pump before it screwed up and sent my cambelt flying off.
  1. Cam belt and water pump
    By tommythomson12 in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2013, 15:06
  2. Timing belt kit and water pump
    Last Post: 21st May 2012, 20:17
  3. timing belt and water pump
    By Garfo in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2011, 21:08
  4. timing belt and water pump
    By mhvcbv in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 13:09
