Thread: Engine management light
    Exclamation Engine management light
    I started the car with the air flow meter plug disconnected (forgot to put it back in after working on the car) and now the management light is staying on .The spanner light comes on with the ignition and goes out when the engine starts. There were no lights before i started the car with the AFM unplugged so will I be right in thinking that after x amount of engine starts the lights will revert to normal. The car seems to run as well as it ever did even with the light on. The car is a 1.9 cdti 16 valve model.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Yes mate, after a number of starts it should go back to normal. Have you tried disconnecting the battery for 20 mins to clear the code?
    Hi rushy, thanks for the reply. As long as the car runs ok I think I will leave it to go back to normal in its own time just to see how long it takes. Cheers.
    Yep, if it only stays on until the engine is started, then it's telling you a stored fault code is present but no longer valid. It's only if it stays on after the engine has been started that there is still a fault somewhere.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
