Thread: exhaust back box help!
    Regular Member signum03's Avatar
    worthing
    confused exhaust back box help!
    as above recently bought a back box for my siggy, changing my self, do you need some sort of lube on the join from the centre pipe to back box to seal, or is it just old one off, new one on , tighten, job done?
    Regular Member Fireyfella's Avatar
    Jun 2007
    York
    Vehicle : Vectra SRi NAV XP2
    Engine : 1.9 CDTi
    Mileage : Plenty
    Quote Originally Posted by signum03 View Post
    'Exhaust Assembly Paste' would do the trick, try halfords it's less then a fiver i think.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You need to take the old one of clean up the remaining pipe (wire brush etc.) and the use some exhaust jointing paste
    WGAF#5
    - make sure the car is cold and hasnt been driven for an hour or two unles you have asbestos fingers then .....treat your self to a new clamp = the parts(pipe and exhaust box) should have a flange (ooh er missus) that meets up and the clamp then pulls them together and holds them in place - the only time you should need any "sealant" is if there is a leak of gasses suggesting that the parts have not fitted correctly to start with
    hth
    regards
    Dez
    worthing
    i assume if you dont it will blow!? stupid question!!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Basically mate yeah
    worthing
    deztroyer- box has a clamp welded onto join already waiting to be tightend, so looks like i just need paste!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Take it that its a genuine box then, should be an "easy fit"
    WGAF#5
    hopefully yes....
    worthing
    yes its genuine and ruddy heavy its the 3.0 v6 cdti!
  1. Exhaust Back Box
    By si_hoss in forum Engine & Drivetrain
    Last Post: 20th September 2010, 19:14
  2. Back exhaust box
    By BUSTER6348 in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2009, 01:39
  3. Cat-back exhaust to 3.2 V6 GTS
    By Raffe in forum Styling
    Last Post: 1st February 2008, 07:33
  4. Replies: 7
    Last Post: 22nd August 2007, 21:16
  5. Cat-Back Exhaust
    By vectrahuw in forum Petrol Engine related
    Last Post: 14th April 2007, 01:31
