Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: 1.9 CDTI problems after cam belt change
    scotland
    Eek 1.9 CDTI problems after cam belt change
    Hi all,
    I did a homer on my cambelt and water pump. Now its being a complete pig to start no matter what time of day I try it. Just wondering if the engine timing could cause it to start badly. When its running its completely fine. The little car with spanner through it comes on for the first minute or so after i start but then goes off. I changed my glow plugs at the weekend and this has not had any impact at all.
    Can the engine run if the timing is out at all?
    Anybody in central scotland got a timing setting kit i could borrow for saturday afternoon to see if that would cure it?
    JP
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    There is no need for a timing kit if you pay a little attention. Have you rotated the engine 2 full revolutions after you installed the tensioner?
    scotland
    Turned it over 6 times,
    then took a break and turned it over again another 5 times.
    bit paranoid i think!
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Just remove the cover and check the mark again on the camshaft pulley and the crank shaft pulley to be ok. First one must be in 1 o'clock position, second one at 5 o'clock position.
    Essex
    Quote Originally Posted by oxenburger View Post
    Hi all,
    JP
    Hi, did you ever solve your timing issue as I am having the same problem?
    scotland
    Default !
    ok number 1, dont drive your car,
    Buy a timing kit they are about 60 quid. Mine dropped a valve, ruined a piston and destroyed the head. So if you can get a timing kit it`ll be a hell of a lot cheaper than what i paid!
    so new pisto, con rod, piston rings, head shells and a lot of labour.
    Simple as buy a timing kit!
    Essex
    ok thanks, I have started it but not driven anywhere, it did start first time but not after that, not sure if I've already done damage, can I ask if yours is the 150 or the 120?
    scotland
    its the 150
    scotland
    mine happened 6 weeks after i`d changed it!
    Essex
    confused timing kit for 120
    Don't suppose anyone here can lend/hire me a timing kit for a 1.9 cdti 120?
    or is it even worth trying?
    Should I do a compression test first?
  1. Is it possible to change Aux belt from top on CDTI SRI 150
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 17th October 2012, 20:24
  2. 1.9 CDTi 150 timing belt change
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2012, 20:15
  3. cdti 120 belt change
    By xf8u39 in forum Engine & Drivetrain
    Last Post: 19th September 2011, 15:05
  4. Vectra 1.9 CDTI cam belt change
    By bravenger in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2009, 10:47
  5. 1.9 cdti sri and 3.0 v6 sri belt change ?
    By STAV in forum Diesel Engine related
    Last Post: 24th June 2008, 16:11
x19dt timing marks
z19dt timing marks
Opel vectra z19dt cambelt change www.vectra-c.com
vectra 1.9 cdti sri smoking after timing belt change
timing belt replaced vectra c 1.9 cdti automatic
z19dt crankshaft pulley woodruff key
z19td tdc
opel 1.9cdti jakomerkit
z19dt timing belt change
