Results 1 to 10 of 13
Thread: noise in dashboard
    Apr 2009
    Bulgaria
    Default noise in dashboard
    Hi,
    I have 2008 vecky c (OPEL i.e. left steering) with CDTI 150.
    For some time there's an irritating noise coming from the dash area. The noise is like from something swaying around and kicking into something. It happens when I'm driving through bumpy road and on a relatively high speed - 30mph. What's stranger is that this happens only when the right or left wheels go over the bump but not when the two tires step together.
    The noise is not always there, though - sometimes it takes 2 hours of driving until it shows up.
    I hear it right in the middle near the front window and around the fog vents. My girlfriend says it's coming just above the glove-box but I'm not quite sure.
    Any idea what it might be?
    Already removed the glove-box but everything seems stable. Inside the bonnet everything seems OK, except the diesel filter which is quite loose and if I push it by hands its moving left-right and up-down, however the noise inside somehow different. Is this loose fitting normal for all veckys? I noticed that the mounting at the astra is very different - seems much more solid
    Jun 2009
    Dublin
    If its still under warranty(1st Year) take it back to the dealer for them to find it
    Good luck though
    Apr 2009
    Bulgaria
    Hi,
    Thanks for the advise. Unfortunatelly the dealer said there's nothing wrong and the they couldn't hear anything. Infact I drove a dealer's employee for 15mins and the damn noise wasn't there. The moment he got off the car the nasty thing came back
    Any idea about the filter. Is it normal to be that loose?
    Thanks,
    Hristo
    Regular Member kev bux's Avatar
    Jan 2006
    BOROUGHPETER
    hi mate,
    i have the same friggin problem,believe it or not. thought my dash was loose cos when i grab it from the clocks area it moves slightly and it does sound like the noise im looking for. checked the screws inside the door front pillar(torx ones) but they are tight. wedged a glove between dash and windscreen and the noise is still there. getting really peeeed off with this now.
    had most of the dash out 4 times and glove box but cant find anything. gonna take a to it soon. lol
    if you do find something please let me know.
    mines a 1.8 16v sxi 2004 hatch
    Jan 2006
    BOROUGHPETER
    bump bump bump.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    hope this helps but it was more of a rattle with me,
    i had the rattle & thought it was somewhere in the Glove box,
    But I've traced it to the fuse extractor in the fuse box next to the glove box
    Jan 2006
    BOROUGHPETER
    definatly not that mate. Thanks anyway. Its got to be something inside the top of the dash. Only does it now and again. Really really doing my effing head in.
    Nov 2009
    Newcastle upon tyne
    confused
    Aye ive got the same problem, sounds like a ticking noise everytime i go over a lump in the road but mines coming from driverside right heater vent somewhere behind that!!!!!!!!!!!!!
    Jan 2006
    BOROUGHPETER
    im convinced its the dash. As i said if you grab the dash above the speedo it moves slightly. Gonna undo the torx screws later that are inside the door pillars and redo them up. This is the most annoying problem to date i have had. Lol.
    Apr 2009
    Bulgaria
    Hi,
    My dash seems to be stable. I'm gonna remove the central vents and see if it something pops up.
    But:
    1. I took it back to the dealer and again I was looking stupid - the thing was almost unhearable. The guy told me it has somehting to do with the whole dash mounting (not sure what the english word is but generraly it replaces the screws)
    2. I don't want to beleave him and continued observation. Now it's quite rainy and I noticed that on a rainy day there's no knocking. Thus I think it still has something to do with the exterior, under the bonnet... So I'm thinking to put some silicone lube at the bonnet mounts.
    flyzepp
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  3. dashboard bit
    By porthy-t in forum Styling
    Last Post: 19th January 2010, 19:18
  4. Clicking noise from dashboard on startup
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2009, 16:54
  5. Alarming Noise from Dashboard
    By decho in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2008, 17:12
