Thread: glowplug light
    Oct 2009
    bristol
    Default glowplug light
    hi everyone recently bought a vectra 03 2.0 dti never had a diesel before the glowplug light does not come on when the engine is cold if and when it comes on do you just start it as normal or do you have to wait for the light to go out what does it look like. also theres a display window in the rev clock whats supposed to be displayed there im not getting anything.thanks for your help.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Ok the glow plug light will only come on when it is pretty cold, I personally wait for it to go out but I believe you can start immediatly.
    As for the window in the rev counter, you don't really want anything to come up in that window as it always indicates a problem, it also displays if a door is open hope that helps
    11 Post(s)
    And it's also for the autogearbox to tell you what gear you're in when using the tiptronic feature, else just displays "D" or "N" etc.
    West
    On the dti the glow plug light will only come on if the overnight ambient temp is 5*c or lower... it's always best to wait for the light to go out,that's when the cylinders are hot enough to fire with less cranking... hth
    Near Warrington
    Also as a general rule the glow plugs are still in action "when its cold",until u actually turn the key to the start position,the light on the dash is just there as a general guide...
  1. no glowplug light, why???
    By frasedeb in forum Engine & Drivetrain
    Last Post: 22nd January 2013, 23:05
  2. Flashing glowplug light
    By Tankman10 in forum Engine & Drivetrain
    Last Post: 8th December 2012, 11:05
  3. Glowplug light vanished!
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 20th August 2012, 21:32
  4. glowplug light
    By clyde in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2011, 00:39
  5. glowplug light
    Last Post: 13th October 2009, 13:54
