Thread: Central locking
    Sep 2009
    Glasgow
    confused Central locking
    Hi all strange problem noticed the range on my fob was getting closer before the car unlocked , so replaced the battery tonight in the required time went outside to open car from the bottom of my stairs as i usually do and nothing not a blip i have to stand just under a meter away from the drivers door before it unlocks remotely with the fob. tried to resync the key using the ingition 2 press lock button but that didn't work tried what it said in the manual by turning key in lock towards front of car and return to vertical will sync the key still have the same problem , i don't think it has lost sync spare key is the same but i swapped the battery over from the spare key to my main key could this be the problem do i need to do anything additional, also a fresh set of batteries hasn't helped why has it lost it's range.
    Sep 2009
    Glasgow
    Smile
    quick update seems to be working ok now, at the shopping center i unlocked my car from roughly 25-30 meters and did the same at another center but when i parked the car in my street same again had to stand about 1 meter too the car before it responded, there must be some sort of interference in the street that wasn't ther before. glad it is just in my street.
    WGAF#5
    try touching your chin with the key - you may look silly but it seems to increase the range considerably - by another 10 - 15 meters in my case
    Sep 2009
    Glasgow
    cheers i'll try that one after dark
    WGAF#5
    Quote Originally Posted by nokiaman1978 View Post
    got the tip off of clarkson on top gear - works a treat -especially when your trying to find it when the car parks full
    Sep 2009
    Glasgow
    yep seen that episode as well.
    Sep 2009
    Glasgow
    just tried it it works Haa!
    Regular Member barkzz's Avatar
    I thought my Central Locking reciever unit was goosed, then i discovered the rear window was ever so slightly open. Shut that, and the problem went away hahah
    Sep 2009
    Glasgow
    will check rear windows as my 3 year old has a habbit of rolling them down when im cleaning the car.
  1. Central locking
    By stevie16v in forum Bodywork & Interior
    Last Post: 21st March 2011, 18:56
  2. Central Locking
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 22:27
  3. central locking help !!!!!!!
    By VECKSZ in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2009, 17:37
  4. Central Locking
    By S14RRJ in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2008, 01:04
  5. Central Locking
    By parapaul in forum General Chat
    Last Post: 18th October 2006, 20:48
