Results 1 to 10 of 14
Thread: vectra c dead on a1
    Regular Member pitsmoor21's Avatar
    Apr 2008
    sheffield
    Default vectra c dead on a1
    Hi all hoping someone could help i was travelling home last night when the oil light came on around a minute or so after i heard a bang then there was a puff of smoke i pulled onto the hard shoulder where i had a 2 hour wait for the aa when the guy had a look it had a 3 inch hole at the bottom of the engine what could have caused it is a mystery was it inside out or did something hit me does anyone know if this has happened too anyone else
    Mileage : 000
    I doubt it that somethig hit you. Is the hole at the front, I presume it is. By the sound of what you say it sounds like a con rod has come through the engine block. But without eiter seeing the damage or any picturs I can not substantiate this. Is it possible to post up a photo. I must admit I have not heard of a "hole" appearing in the engine block for many many years.
    Again wothout futher info" it goes sound a bit like mechanical faliure some where.
    Apr 2008
    sheffield
    ill try get one on tomorrow mechanic is coming i bet thats gonna cost me a pretty penny
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    yes, i would say something inside has "punched" a hole though the block. my old vec did the same but to the gearbox. sorry to say it, its going to be an expensive time for you.
    on another matter why did it take the AA 2 hours to arrive ? (do they not guarantee to be with you within 40mins ?) is the car at home or at a garage ?
    Mileage : 000
    If there is a hole in the engine block, you will need to remove the engine a new block will be needed. then all the top end will need to be removed and refitted to the replacement block. It probably will in the end work out cheaper to get a replacement engine. I would have a look on ebay, just in case, to give you a rough idea of some of the cost.
    Edinburgh
    this happened to my brother's Fiat Coupe. Conrod ejected itself through the engine block. He ended up buying a new engine.
    WGAF#5
    your oil wanring light was probably pointing at low oil/pressure problems the car continiued to drive without sufficient lubrication and something has got very very hot and siezed = resulting in the engine letting go
    i'm sure this is not what you needed to hear - but it is sounding like a new engine - was everything else ok before - no noises or other issues??
    not leaking oil - havent had to keep topping it up ??
    Apr 2008
    sheffield
    i was not with the aa when the breakdown happened so i had to sign up there and then so by the time id done all this time had gone that taught me a lesson and the oil levels were fine even when the aa man looked and no real issues with the car although i had heard a tapping noise the other day when i was driving. like ppl are saying i think its gonna be a tight christmas this year
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Yea mate sounds like its thrown a rod, new engine IMO, not very common TBH but none the same.
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by moorlander View Post
    the AA, Dont make me laugh I was working near ASTON on the A 530 between Nantwich and Whichurch, I Justed wanted a jump start as I had left my side lights on all day ( yes I know) phoned at 1720, long story but the got me a jump start at 2200, they used contractors, I got a letter, sorry was all I got, ******S
  1. Dead vectra
    By yodaboyo in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2010, 21:42
  2. Dead Vectra?
    By Vectra-c-SRI in forum Engine & Drivetrain
    Last Post: 5th May 2010, 09:24
  3. my vectra dying or dead
    By shaper546 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th April 2010, 19:20
  4. Dead Vectra
    By Adamant in forum Engine & Drivetrain
    Last Post: 23rd August 2007, 13:46
  5. Dead Vectra
    By janc in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2007, 01:00
