Thread: will showroom shine strip wax ??
    Regular Member nigec's Avatar
    barnsley
    Default will showroom shine strip wax ??
    Last time i washed the car i applied a coat of FK1000p , now its needs a quick wash. If i wash then use showroom shine as a quick detailer to bring the shine back ,will it strip the coat of FK off ??
    Cambridgeshire
    Quick detailer will not strip the wax that you've put on, it will act as a form of top up and add the shine that it desired.
    I tend to use QD on mine when I give it a wash and every 2 months or so give it a good clean with 2-3 coats of wax
    HTH's
    Regular Member Cossy's Avatar
    East Yorkshire
    dodo juice red mist is great stuff...its abit better than a normal QD, tops up your wax protection without having to re apply wax and works like a normal quick detailer, spray, wipe on and off.
    Regular Member david.aka.judas's Avatar
    Suffolk
    red mist is good but can be tricky, red mist tropical is less so because its less chemically. red mist can be a pain in hot weather or on hot surfaces because it dries so quick.
    the megs sprays are more user friendly.
    a qd (sealant) that beats everything is Z8 by zaino - it works a treat - very impressed.
    http://www.cleanyourcar.co.uk/zaino/.../prod_471.html
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i use meg's final touch, brought by the gallon and diluted at home...find this very good indeed and as already said act's as a top up to your wax.....
    Midlands Mod Shop - NFFC.
  1. showroom shine
    By pipamish in forum General Chat
    Last Post: 7th January 2013, 12:26
  2. showroom shine
    By big tee in forum Detailing and Car Care Discussion
    Last Post: 28th November 2011, 21:29
  3. Greased lightning showroom shine
    By ShauneDTi in forum Detailing and Car Care Discussion
    Last Post: 18th May 2010, 18:40
  4. anyody used showroom shine / spray and shine
    Last Post: 10th October 2009, 22:18
  5. Greased Lightning, ShowRoom Shine
    By Simo87 in forum Detailing and Car Care Discussion
    Last Post: 10th September 2009, 23:13
