Results 1 to 10 of 13
Thread: Service Light?
    Jan 2006
    milton keynes
    Default Service Light?
    Howdy,
    My car is being serviced by a mate of mine and i was wondering is there anyway i can reset the service light myself without the use of a main stealer? can it be done? or will it need one of those diagnostic thingamajigs doing to reset it?
    Jan 2006
    milton keynes
    anyone?
    Ashington, Northumberland
    This procedure doesn't always work and if this doesn't work then it will need Tech2 treatment at your dealer but anyway, try this:
    1)Push in and hold trip counter button on dashboard facia.
    2)Whilst holding trip counter button in, switch on ignition
    3)still holding trip counter button, press brake pedal and hold for 30 seconds.
    I'm not winding you up, that is the correct procedure, but as I said above, sometimes the system is locked and this procedure will not override it so you will need Tech2. Let us know if it does work though. HTH
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    That is the correct procedure, don't think you need to hold brake pedal. it should fully reset the counter / timer.
    It is fairly well documented on this site.
    Jan 2006
    milton keynes
    magic cheers peeps.
    can i do that after evert service?
    yep, the reset works every time for me so-far..
    May 2006
    cramlington
    thanks it worked but i had to switch on sidelights aswell.
    derby
    Default service light
    2004 vectra 1.9 CDTI just require clear instructions on re-setting service indicator. After turning off ignition an pressing down the button near the petrol indicator and turnin on ignition display changes to a reading which says 1.5 at the bottom right but above a long set of numbers. What is the correct method or is something wrong that is beyond anyones knowledge
    You also have to press the brake pedal as well as pressing the trip reset button.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    IIRC you only need to depress foot pedal and/or switch on sidelights on facelifts. Works OK without doing either on my 04 2.0T
  1. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  2. service light
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2009, 21:01
  3. Oil Service Light
    By welshy in forum Engine & Drivetrain
    Last Post: 24th October 2008, 11:42
  4. service light
    By jaff in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2008, 11:02
  5. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
2004 vectra c 2.0t service reset
