Results 1 to 10 of 11
Thread: Brakes What Tools
    worcester
    Default Brakes What Tools
    I have a signum 2.0dti 2004 that requires new front and rear discs/pads, reading the how too I need the follwing tools:
    1. T30 Torx Bit (male) 1/2" socket
    2. E20 Tx star socket (female) 1/2" socket
    3. 7mm allen key
    4. long nose pliers
    Do I need anything else?
    Price for kit's £51.02 each from Auto Vax, but don't say what make, what make is best i.e ebc etc?
    A very long breaker bar, lots of WD40, and a very large hammer...
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Also a rewind caliper tool to do the rear pads
    worcester
    Looks like the list tools is right so the tools are now on order and next weekend if it does not rain the work starts. Just got to print out the how too.
    Thanks for the replies.
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by Daywalker View Post
    I think the long-nose pliers were to be used instead of the rewind tool.
    [Ex]Admin Duncan's Avatar
    Rewind tool ideally and an E18 socket for the rears.
    As you've listed, get 1/2" sockets as with the long breaker bar (which you'll need and possibly a bit of extra 'extension' like a short bit of scaffold pole) you'll have no bother.
    It will help if you apply a bit of heat to the caliper bracket torx bolts as they have thread lock compound applied to the threads before they are fitted and heating them softens the compound and makes the bolt easier to undo
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Torque wrench may be a good idea as well dont want to sheer a bolt with the breaker bar!!!!
    Torque wrench to undo the bolts you mean? If so, definitely not a good idea. Easy way to wreck a torque wrench. Also if you're undoing a bolt how would you use a torque wrench for that? If you set it to a particular setting and tried to undo the bolt, if it didn't loosen the bolt before that setting then the wrench will kick in and start clicking.
    For tightening the bolts then yes, obviously good to have one.
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    sorry yeah didnt make clear, for re-torqueing the bolts afterwards, have seen someone use an improvised breaker bar (piece of scaffold bar) and take the head clean off he was not happy!!
  1. Tools what do you have?
    By Bigtee in forum General Motoring Chat
    Last Post: 31st January 2012, 13:58
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. what tools do i need for rear brakes on 2.0 dti?
    By MCD in forum Handling & Braking
    Last Post: 10th March 2011, 17:47
  4. Most used tools
    By Tadpole in forum General Chat
    Last Post: 25th January 2009, 22:09
  5. My tools
    By thestaffy in forum Detailing and Car Care Discussion
    Last Post: 21st January 2007, 18:54
