Thread: BSR
    Enfield
    Question BSR
    Hello peeps,
    I have S2 and im over the moon with it but i now would like to to Mach 3 (S3).Will this work without the downpipe or will this damage the turbo?
    Cheers.
    Regular Member Readster's Avatar
    Plymouth
    Quote Originally Posted by gingeronaninja View Post
    Hello peeps,
    Cheers.
    translation service please....
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    ok you have what car exactly ??? and have you got stage 1 now ??
    for stage three you need different injectors downpipe and exhaust system ...HTH
    Enfield
    Sorry,
    I have a Vectra 2.0t 2003 Stage 1. My question is if i install the injectors and the map without the downpipe will it damage my engine or turbo.
    Regular Member Matt&Jemz's Avatar
    CORNWALL
    we have stage 1 but with the downpipe and custom exhaust it goes well souds great but eml is on almost all the time dunno wot it is code reader says air flow meter fault but replaced it and its still the same
    so be careful and bsr wont help much
    thats just our view
    but it did go very well round the ring which was good
    Enfield
    Still seems a lot of money for a downpipe, but i cant forget the smile it put on my face when upgaded to stage 1. Stage 3 is calling and the wifes already nagging.
    Cheers for the info.
    [Ex]Admin Duncan's Avatar
    Without the downpipe you'll be strangling the performance as the map is designed to work with the full kit i.e. downpipe, exhaust and injectors and it also has a sports cat in it so you ditch the standard (restricting) cat that you have at the moment.
    It's not cheap (the downpipe) but there's a reason for that.
    Look at blue estate's thread on him getting S3 as he got his downpipe for a good price. I got my kit for an even better price but if I told you how much I'd have to shoot you!
