Thread: 3.0 v6 cdti injectors/hp pump part nos?
    France
    Default 3.0 v6 cdti injectors/hp pump part nos?
    Can anybody give me the part nos for these for 12/2003 car, auto estate lhd as I want to see if they can be sourced other than from opel/vx/
    There are some things that can be done, before the time and cost of replacing the SCV on the high pressure fuel pump
    Some simple diagnostics first
    Lack of power at between 1800 and 2500rpm
    The turbo can be heard operating continually on / off / on / off / on / off when at a constant speed and in this rev range where power fails
    A simple solution is to manually vary the pressure to the fuel pump
    This is done by slowly applying the accelerator on / off / on / off / on / off
    The revs will then rise, a small increase power will then return
    You may find the revs are limited to about 3500rpm, this is normal
    Obtain two bottles, at least 500ml, of diesel injector cleaner
    To an ALMOST empty tank at about 1/8 mark, carefully add ONE bottle
    Take the car for a drive of about 10 miles on roads with speed limits of about 40mph, don't go too far from a petrol station (plan the journey accordingly)
    The fuel tank warning light will come on, make your way to the petrol station so that you get there as soon as it starts flashing
    To this ALMOST empty fuel tank, add the SECOND bottle, and about 14 litres of diesel
    Take the car home and LEAVE for at least 12 hours
    After 12 hours take the car to the highest speed and revs you can get
    The contaminant should eventually clear the SCV
    It may cause the EMS to return a fault as the fuel pressure will suddenly change
    This should take no more than one tank of fuel, so repeat the process over the next few days
    Full Member
    Bristol
    Littlejohn. Go and see your local renault dealer. The V6CDTI izuzu engine is a standard fitment in the renault espace. The engine is also fitted and the saab V6 tid. All parts are the same.
    I currently have one SCV sitting on hold at my dealership
    I will go in on Friday and get the part number, albeit it is the GM part number
    I will also see if they will give me a photocopy of the repair sheet, which has all the instructions
    France
    Thanks, M8internet.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Injectors are 97239161
    HTH
    Might be sooner than Friday, the fuel pump appears to be blocked again, and has stopped the revs going past 3000rpm
    France
    Thanks Celes,
    I have had mine into a uk dealer today. Still no codes but they apparently did some tests of the fuel pressures whilst road-running the car. They say the reading should be 150? but mine was only 30 when accelerating and therefore the SCVs need replacing. 7 hours and £150 for the scv kit. I said ok but then they discovered the parts are back-ordered! Are well, limping back to France tomorrow.
    Quote Originally Posted by littlejohn View Post
    It should return a fault code with the low fuel pressure
    However, it may return as "fuel system - unknown error" and hence why the engine warning light doesn't come on and the car isn't put into safe mode
    Once the car has had the EMS update this will be corrected with an actual fault code that makes sense!
  1. How would you cure a air lock from fuel pump to injectors?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd November 2011, 00:16
  2. V6 3.0 CDTI Injectors
    By r.bailey63 in forum Engine & Drivetrain
    Last Post: 13th February 2010, 21:36
  3. Injectors x4 1.9 cdti 150
    By mark230678 in forum Parts for sale
    Last Post: 30th June 2009, 22:05
  4. 3.0 CDTi Injectors
    By Robbieben in forum Parts for sale
    Last Post: 1st February 2008, 23:17
injector part number for vectra 3.0 v6 cdti
