Thread: Door Card Removal
    Default Door Card Removal
    Picked up my new mirror today, and I'm amazed by what I got for my £35.... Its the whole mirror, including the bit that fixes to the A pillar, just excluding the motor and the glass!!!!!
    Anywho.... I now need to know how to get the interior trim off the door (the whole door card) without destroying it!!! so I can unbolt the old mirror and fit my new one.
    Anyone with TIS help????
    Regular Member Harry's Avatar
    Uxbridge, London
    Well Duncan just did this exact thing to swap the moisture barrier lining that is stuck to the door so i'm sure he'll be a good person to ask.
    Is the shell already painted? Surely that wasn't included for 35 quid.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Harry
    Ta daaa - and here I am!!
    PDF here.
    You need to unscrew five T20 Torx screws. Three at the bottom of the door card and two behind the grab handle. You need to remove the cover on the handle. Get a plastic wedge of some sort. I found that one of those flexible plastic cooking/mixing spatulas works a treat. Don't be tempted to use a screwdriver, you will leave little nicks. Gently ease the wedge/spatula under the edge of the cover to get some space to get your finger nails in. Pull the top of the cover towards you (not the bottom as it has a lug down there) with some force and it'll pop out. Undo the last two screws.
    For the bit that shows pushing the door card up with a long stick thing, get something like a small hammer (the type with the thinner wooden shafts) and stick the end of it up into the top of the door card.
    Then you just need to unclip the Bowden cable and disconnect the tweeter connector and connector for the door/window controls.
    You're likely to break the odd fastening plug when you remove the cards. Maybe just get a few spare in advance, or do it early enough in the day to allow yourself time to get any that you need from the dealer.
    If you come across any problems, give me a shout on MSN if you like as I've done this umpteen times - most recently at the weekend taking off all four door cards. The reinstalling can be a bit tricky.
    EDIT: BTW - ignore step 6 about 'Detach window channel strip from door inner trim panel • see operation "Window Channel Strip – Front / Rear Door, Remove and Install"
    It's not necessary. You can remove the whole card with that bit in one go.
    HTH
    All done, and not a broken clip in sight..... just gotta refit the panel now. New mirror is looking good (compared to the broken one anyway!!).
    Thanks D, thats another drink I owe you eventually! (Or would you settle for a bag of donuts!!!)
    Quote Originally Posted by Jamie1979
    Excellent!
    No problemo.
    Beer or donuts? Hmm, let me think about that for a nano-second.....I guess you're getting the beers in Jamie next time we meet!!
  1. door card removal
    By dave_veccy_c in forum Bodywork & Interior
    Last Post: 2nd April 2010, 10:37
  2. Rear Door Card removal
    By yadziyad in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2010, 01:02
  3. Rear Door Card Removal How To??
    By AirCooledHeaven in forum Bodywork & Interior
    Last Post: 8th September 2008, 09:29
  4. Drivers door card removal
    By MadOnVaux! in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2007, 17:46
  5. 05 sri door card removal same as 04???
    By Nickzx6r in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2007, 13:35
