Thread: CCR 2006 Help :)
    Sep 2009
    N.Wales
    Default CCR 2006 Help :)
    Hi guys I have a Vectra edition 100 04 with a CDR2005, i have recently bought a CCR 2006 (multichanger) to replace this but when i removed the old stereo and tried to insert the other one it goes half way an and wont go any further, the plugs etc all line up so not sure what the problem is. I shouldn't need a new cage for a vx standard upgrade?
    Chris
    Sunny Dartmoor
    I've just done exactly the same,remove the cage and push the side's of the cage flat against the rest of it,then it should fit no probs,hth.....
    Sep 2009
    N.Wales
    i c , I have never done this before it was recomended by a firend ermm how do i get the cage out? there is a screw at the back in the centre which i have removed but it still seems solid. And do u mean fold the metal bits of the cage against the side and then refit it? sorry for being a bit dumb dont want to wreck it lol
    Cheers mate
    Sunny Dartmoor
    Remove the screw,move the side's of the cage inwards and then it'll sort of fold up and should come out with a bit of a struggle,then remove the plug and ariel from the cage,good luck.......
    Sep 2009
    N.Wales
    Cheers mate modification done all fitted thanks.
    Sunny Dartmoor
    Great,glad to help....
  1. 2006 Vec SRI 1.8
    By Nickg in forum Tuning
    Last Post: 4th September 2010, 20:17
  2. Ccr 2006
    By R13hard in forum Parts for sale
    Last Post: 9th December 2006, 21:18
how to remove vauxhall ccr 2006 bolt at back
how to remove bolted in ccr 2006 from a vectra c
removing ccr 2006
