Results 1 to 10 of 20
Thread: Latest Mod
    Swindon
    Smile Latest Mod
    After reading the thread with regards to the Insignia washer jets, i felt it must be worth a go for a couple of quid.
    Popped into vauxhall this evening and gave them the part numbers, they had them in stock. Haded over a fiver and got changed, very impressed.
    Came home bring out the tool box.
    items required.
    1 flat blade screw driver
    13mm socket wrench.
    removed the wipers,
    removed the scuttle panel
    disconnected the water jet pipes
    popped out the washer jets
    fitted new washer jets and refitted as removed
    hey presto
    30 minutes start to finish
    results.
    Wow what a difference. no longer 2 rubbish jets from each washer, a really effective fine spray which covers the whole screen and washers far better than before.
    Excellent mod, well worth doing, fully recommend to anyone thinking about doing it.
    Regular Member signum03's Avatar
    worthing
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Did mine too. Only i just lifted the panel up and popped the old jets out and put in the new ones. Total time 4mins. I do agree that the spray is much better and i emptied the washer bottle testing them out
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    No need to remove wipers at all. Just lift scuttle panel and push the jets down.
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Quote Originally Posted by Graham View Post
    Agree on not removing the wipers, that is the hard way
    Swindon
    i looked at doing it without removing the wipers and the scuttle panel, but each washer jet is help in by a little clip which you need to push back to get them out, and i have a knack of breaking things when using too much force, so i took the safe route.
    agreed, you can do this with out removing the panel, i guess i'm just cautious.
    End result is the same, a nice clear screen at long last, for less than a fiver. cheapest most noticeable mod ever.
    cheers to the original poster who found this out.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Yep, CristianTM really did find a juicy cheap mod to do with this!
    Did mine yesterday, but preferred the knuckle scrape and a mug of hot water to loosen off the old jets.
    Predictably, I emptied my washer bottle within minutes.
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Any one know if there are heated Insignia washer jets out there for sale?
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    Quote Originally Posted by tonyt View Post
    items required.
    13mm socket wrench.
    removed the wipers,
    hey presto
    results.
    have you got the part no.s ???
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Quote Originally Posted by Grimo72 View Post
    12782508 and 12782509
  1. Latest and best mod so far!
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 20:23
  2. Latest mod
    By kman247 in forum Styling
    Last Post: 19th February 2010, 23:40
  3. Latest Mod
    By JSYSH466Y in forum Styling
    Last Post: 25th February 2009, 22:08
  4. Latest Mod
    By bigmac in forum Styling
    Last Post: 16th February 2009, 09:45
  5. Latest Mod
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2007, 10:41
