Thread: steering wheel control help!
    Regular Member signum03's Avatar
    worthing
    confused steering wheel control help!
    morning all, i have ordered new radio/cd controls for my pre facelift signum 2003 (6 button) just looked in the haynes manual and it says you need to remove the air bag! is there any other way just to swap them over? thanks in advance.
    WGAF#5
    Quote Originally Posted by signum03 View Post
    yup !
    torq screw on the rear holding them in place
    then gently prise away - remember there is a wiring connector behind
    - fit new and then gently push onto wiring connector and hey presto job done
    worthing
    so no danger of the air bag goingn off??? if not removing
    WGAF#5
    none whatsoever
    if your worried about an inadvertant activation - disconnect the battery and then leave the car to "power down" for about half an hour
    but if you do this you will need to reset clock - radio (code) and windows
    then the car will need to relearn its characteristics
    took mine off without battery disconnect - and drove around for 2 days with no buttons whilst i repainted my covers
    Sep 2009
    Northern Ireland
    confused
    I bought replacement audio controls for my 05 vectra (part # 931832987) but they are a different size than the ones on my wheel!
    Thot i'd bought the rite ones! grrrrrr
    does anyone kno wer i can get the bigger ones from? mine r the roller type buttons.
    worthing
    main dealer, or you might be lucky on ebay! just bought a 6 button type for £28 whole set from stealers.cant see them being much more for the rollers? not sure though!
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    You just have to be careful when you re-assemble as the locating prongs sometimes bend and the panels dont sit flush.
    Taking the airbag off though if you have to is a very simple job - done it loads of times with no issues...
    Regular Member dti owner's Avatar
    dover
    Vehicle : SRI
    Engine : 1900
    Mileage : 180000
    Hi i have bought the new shape controls for my preface vectra but have looked and cant see how i can connect them in the wheel as the wires wont plugin anywhere.
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yes because they arnt for your car there for full canbus !!
  1. Steering wheel control wiring
    By the-converter in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2011, 12:37
  2. Steering wheel control
    By RLT in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2010, 18:10
  3. steering wheel control
    By steeb82 in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2008, 22:32
  4. steering wheel control for a Kenwood
    By jamesr in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2007, 20:48
